Question about Mitsubishi Televison & Video
Help me please
Hello my name is Jessica Prejean and i have recently purchesed a mitsubishi vs 70709 television from a friend and i was on my way home and the wind blew out the front screen of the television. the main screen that the picture is on is fully intact and works properly. I am wondering if there is any way to replace the top screen to the television.
  • 18 Answers
SOURCE: Mitsubishi VS-60707 60 in. Rear Projection Television
When it gets better after warm up it can be a capacitor in the 160 Volt high voltage circuit or a cold solder joint. these 2 thinks would be my best guess on this set.
Posted on Dec 27, 2007
  • 1153 Answers
SOURCE: Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Posted on Dec 29, 2007
SOURCE: VS-50605
vertical sync- top of picture pulls to right on intermitently. Fly back?
Posted on Jan 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi VS 60609 60 inch
Which board are you looking for? I can probably help ypu out.
Posted on Feb 22, 2008
  • 395 Answers
SOURCE: 1998 Mitsubishi vs-60601 picture is dull and not as vibrant as it should be
the first thing I would do is to clean the lenses of the CRTs they may be coated with dust that will dim the picture. other than that the CRTs may be failing since the phospher of CRTs fade in brightness over time and the only solution is to replace all three CRTs. the CRTs I have discovered are no longer availible.
Posted on May 04, 2008
Reset passcode for vs60609 Mitsubishi tv
check the english service manual
http://www.manualsdir.com/manuals/118985/mitsubishi-electronics-vs-60609-vs-70709-vs-60719-vs-45609-vs-55609-vs-50609.html?hl=ru
Mar 16, 2015 | Mitsubishi Televison & Video
Tv turns on for 20 secondsthen shuts off
There is short circuited component/s at its circuit board. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. google.com/+GopakumarGopalan
Nov 02, 2013 | Mitsubishi VS-70709 TV
Screen was ok and suddenly make a noise as a short circuit and te screen went out
oops-This is dangerous for peple not trained in service 1-Possibly high voltage makes arc to ground.2-check horizontal output for bad contacts.
Oct 02, 2013 | Mitsubishi VS-70709 TV
What fuses go to model vs70709 television 70 in and where can I purchase them
hello
There may be any reson for the fuse to blow up. Some kind of short circuit may exist in your TVs mainboard, or power supply regulator section. Usually colour TVs uses 3.5amps fuse in series with mains supply. If it blows off again and again; you should contact a technical expert to retify the problem. Never put no more fuse in it as experiment. It may make your TV irrepairable.
Oct 16, 2010 | Mitsubishi VS-70709 TV
I NEED TO MOVE MY MITSUBISH VS 70709 UPSTAIRS AND I NEED TO KNOW HOW TO TAKE THE BASE OFF FROM THE SCREEN
This may be one of the models that comes apart--if it is on either side you will see two plastic caps--beneath are either regular bolts or L shaped ones you turn.
Most of the sets that had the feature needed the front screen removed first to do this.
If you do not see the black plastic caps (two on either side) it does not have that feature.
SD TECH
Sep 28, 2010 | Mitsubishi VS-70709 TV
Something buning back of tv red lines going off
Ur tv have convergence problems,it dead.Ur 2 STK convergence ICS are defective,and all or some of it supporting resistors.The shop will cost u $300-350 for parts and labors.
May 08, 2010 | Mitsubishi VS-70709 TV
My VS-70709 willclick when the power button is pushed, but will imeditaly turn right back off. Any ideas?
HI, you have a weak ballast. this is the power regulator for the lamp in your set. replacing the ballast will fix this issue.
Jul 23, 2009 | Mitsubishi VS-70709 TV
I have a VS 70709 not getting any picture
Code 2_3 is Horizontal Deflection Problem
Jul 01, 2009 | Mitsubishi Televison & Video
Tv is dim
Ned more info as do all things including the on screen display look darker then normal???how old is set??
Mar 31, 2006 | Mitsubishi VS-70709 TV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
