Question about GPS
I bought a gps blackbird ioo When i charge it up for 8 hrs and try to use it by carring it the battery goes dead in 4 minutes .the book says it run for 2 hrs Is thisa poor battery Burnell Beilke [email protected] Buffalo n. dak 58011
  • 73 Answers
Ys sound like bad battery try new one ok and dont leave it on all nigght
Posted on Mar 15, 2008
SOURCE:
How do I use a battery charger to charge my dead battery on a 2001 camaro
The red clamp on the charger goes to the + sign on the battery. The black goes to the -. I you want a deep charge(best) set the charger on 2 amps and run it for 8 to 12 hours. If you need to get the car started, set the charger on 225 amps for just a couple of minutes. Start the car while it is on..2 amps can charge forever. 20 amps for 30 minutes. 30 to 40 amps for 15 minutes. 225 amps for five minutes..DO NOT charge 20+ amps for hours. It will kill the battery
May 12, 2014 | Cars & Trucks
Why did my lights go down and battery volts drop?
First put your battery on a slow charge 6-8 hrs.then check the batteries voltage it should have at least 12-12.8 volts if it does'nt then you need a new battery.If has 12 volts after its charged and goes dead after its installed in the car then you need a new alternato.
Jan 27, 2012 | 1995 Cadillac Eldorado
How long does it take to charge up we just bought a new one and it was plugged in the car for 2 hrs and only lasted about 2 hrs
Garmin satnavs come with a charge out of the box. In most instances you will not need to charge before using. Your device will charge while attached to your 12V vehicle power cable.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours
Your device should be fully charged after applying one of the steps from above.
Aug 09, 2010 | Garmin nuvi 250W GPS Receiver
How long to charge battery?
bateries have their own specifications.You can read it on the label.But,most of all it must be charge from 12-15 hrs. on its very first charging ( for a new battery) and later on or for the second time and so on, you may charge it 2 to 4 hrs.,sometimes 8 hrs..Leting you know,a battery can be charge even a short span of time,for example is 30 minutes only.In that 30 minutes try to measure its stored volt using a volt meter or a multi-tester,and the result is laready 12 volts (if your batery is 12 volts.)do you believe that? YES.! because a battery is so easy to store power.But,the problem is that its so easy to drain its stored power.You know why?because the current or amper of the baterry is still weak that the given specification.,.So,for short explanation,the longer time you charge your batery equals the longer time to drain the power.For example: when you charge the batery within 4 hours,thus the batery will be drained after 4 hours.
Oct 31, 2009 | Black & Decker 8 Inch 12 Volt Cordless...
HP PDA h1940
I just found the most protracted set of instructions to reset it for reference.
1. charge on ac only = 8 hrs
2. remove battey, soft reset, reinsert battery
3. charge on ac only = 30 minutes, remove battery, remove power, hard reset then soft reset.
4. charge on ac only = 4 hrs
5. Power off. Soft reset.
Oct 13, 2008 | HP iPAQ H1940 Pocket PC
The Gps won't turn on and I can't continue the setup.
It just shows in light grey on the screen that it is charging your battery. that take 10 hrs. When itr's done it says - charging complete.
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin ique 3600 won't turn on after battery goes dead
You have to charge the unit before it will start from a dead battery (usually about 10 minutes) before even trying to start the unit.
Jan 10, 2008 | Garmin iQue 3600 GPS Receiver
Screen goes dead
"goes dead in two minutes. recent thing. downloaded update. same in 5 mins."
Try charging the battery. Does it die when connected to the AC charger or computer?
Try reloading the update.
Nov 12, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
37 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
