Question about Nokia N70 Cellular Phone
No power water damage
  • Rick Piper May 05, 2008
    Tried this intricate manouver to no avail...still no life/display at all. have opened with screwdriver.. cleaned off some gray oxidisation apparent... any ideas ?
  • villijos1858 Sep 17, 2008
    my n70 got wet two months ago, i cleaned some oxidations, tried to insert a good, fully charged battery (by the way, the phone is not shorted anymore after cleaning) but still no power. I tried another solution posted here ( *, send, 3 then power on ) still to no avail. What should I do next?
    President:
  • 1,017 Answers
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
"Women are, by nature, exhibitionist. Men are, essentially voyeurs."
Posted on Apr 23, 2008
No power. how will make it power on
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
My phone will not turn on there is no water damage or any damage
Did you look inside the phone to see if the white dot is red? If it is read then somehow water got inside the phone. If it's still white, you might try a hard reboot. Hold down the power button until it powers off (don't hit the power off button) just hold down the button until the phone is off. Then reboot and see how it does.
Sep 11, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Water damage repair
If its water damage you are having, then go see a person with skills in electronics and maybe he/she could fix it for you.
Aug 10, 2014 | ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip...
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
My blackberry screen sometimes works, it powers up but the screen is either blank or the keyboard goes fuzzy and out of control. is it a water damage?
You can check if it water damaged by taking the battrey out, you should a white box this will show no water damage but if shown as pink then the handset is.
Hope this helps
Feb 08, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Water damage to Nokia 6682 and won't turn on. Can
First never turn on any phone after be drop in water ! it's cause a electric shortcut and damage the phone.
I recommand to find a expert because the operation is manually and requeste a to be expert.
But if you can:
  1. open the phone
  2. clean it with a solution that can asperat and vaporate the water
  3. use some warm air to blow it over the chip like dryer
good luck;)
Sep 09, 2009 | Nokia 6682 Handheld
Water damaged, No Power
ur handset 3 time washin in washin machin with ariel.
Aug 30, 2008 | Nokia 6300 Cellular Phone
WATER :-O PLEASE HELP
Hello scared2008,
I am sorry to hear about your MP3 player. Sadly, water and electronics do not get along. If the unit was submerged there is bound to be some damage. Still, there are some things you can do to minimize the damage,
First, make sure the unit is powered off and do not attempt to power it back on until you are sure it is completely dry both inside and out. If the battery pack is removeable take it out. Water will short out and damage components that have power applied to them.
Secondly, dry the unit thoroughly both inside and out. You can wipe water off the outside using a dry towel. For the inside, you can try using a handheld hair dryer. However, heat can also damage the unit so make sure you use a dryer with a "cool air" setting. Blow air into the unit through the headphone jack, USB port, etc.
Give the MP3 player plenty of time to dry out. Wait until you are sure it is completely dry. And then wait a few hours longer. Afterwards, you can try reinstalling the battery (if needed) and powering the unit up.
Even if you managed to get the power disconnected and everything dried out as quickly as possible, the sad fact is that the MP3 player may still have sustained major damage. Some electrical components are made of carbon paper and can absorb moisture. So, even if there wasn't an electrical short some of the electronics inside may not work.
It's possible that a unit with water damage may be repairable. You will want to contact he manufacturer about that repair if needed. Unfortunately water damage would probably not be covered by any warranty the unit might have, so you will probably have to pay for the repairs. Depending on the extent of the damage it may make better economic sense just to replace the unit with a new one.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
Samsung D900 Mobile Phone
May be the phone was water damaged. This kind of problems normally we see in water damaged phones. If not water damaged then PA (Power Amplifier) may be shorted and need to be changed.
May 16, 2008 | Samsung SGH-D900 Cellular Phone
Nokia N70 Cellular Phone Logo
119 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
