Question about Hitachi 26LD6600 26 in. HD-Ready LCD Television
Remote or tv buttons
The picture gets red then just light and the remote or tv buttons to not respond until I turn of the power for little while.
    Problem Solver:
  • 8 Answers
Replace the Z Sustainer Board, Part # 6871QZH044B and replace the Y Sustainter Board, Part # 6871QYH039B at the same time. If you replace one and not the other the bad one will end up shorting the good one and you’ll lose your picture within a week. You can do this work yourself by unplugging the unit and placing it face down on carpet (put down a soft blanket to protect the screen) and unscrewing the back of the unit (a power screw driver works great for this job because there are a few screws involved). The cheapest place to buy these two parts are: www.discount-merchant.com , or www.avextra.net, or www.ebay.com
Posted on Apr 14, 2008
SOURCE:
My Samsung TV doesn't show a picture, when there was a picture audio and remote not working. Which boards need replaced?
If there is no audio then most likely your main board. If your red power stand by light blinks less than 3 s then its the M/B. If its more than 3 s then its the P/B.
Sep 03, 2015 | Samsung PN50C550 50 in. TV
I have a Sharp flat panel model LC-20SH4U. The units power LED light is red. No effect (sound or picture) when remote or on/off switch is activated. The LED light slightly blinks.
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope this may help;
Regards,
VOTIT
Aug 09, 2008 | Televison & Video
Philips LCD TV Red Light Stays On, TV won't turn on or respond in any way
Could be power supply failure or you may not be using the "hospitality" remote.
Aug 13, 2014 | Televison & Video
Haier HLH406BB 40 in. LCD HDTV - tv will not turn on. is not responding to either panel or remote power buttons. red off input light is still lit.
hi sounds like a power supply fault could be capacitors, look for tech in your area good luck
regards
shaun
Jan 15, 2014 | Televison & Video
Red Light Won't Stay On
1. Remove batteries from remote to "zero" it, then reinsert batteries
2. Turn on TV (RCA?)
3. Press and hold CODE SEARCH button until indicator lights
4. Press and release TV button. Indicator will blink and remain on
5. Enter code from list in instructions
6. Point remote at TV and press on-off button. TV should turn off
7. Use remote to turn TV on again and press CH+. If TV responds you're all set; if not, repeat the process with the next code
Nov 19, 2012 | RCA CRK76TE1 UNIVERSAL REMOTE - With...
Unlock my remote
First of all have you checked the remote with fresh batteries in.
Check there`s no obstruction between remote and tv.
I can get the codes for a universal remote 01 or 02
try those on your sharp remote.
Another way
If you don`t have codes,I can tell you how to find the code on your remote without pressing any numbers!
Hold the code search button until the red light on the remote remains on. Then, press "TV". After this, point the
remote at your television and press the power or on/off button over and over again SLOWLY (one time every second) until
the TV turns off. DO NOT PRESS THE POWER BUTTON AFTER THE TV TURNS OFF!!! Once it does, press the "enter" button on the remote. Then, the remote should work on the TV.
Hope i`v helped!
Dec 02, 2009 | Televison & Video
I need the codes for a brightstar br100z remote for a symphonic t
Hold the set up button until the red light stays on on the remote. Press power until the TV responds. My sleep timer displayed after 23 presses (hotel room Magnavox TV). Stop pressing remote. The red light will then flash a few times once you stop. Problem fixed.
Feb 01, 2009 | Universal Remote Control Remote Control
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Hitachi 26LD6600 26 in. HD-Ready LCD Television Logo
49 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
