I have a Acer Aspire 5050 Laptop and I've bought a new battery and a new charger but for some reason the laptop doesn't recognise when the charger is plugged in. So now the laptop is out of battery and i'm stuck with out it ! Any help would be appreciated ...
1. Battery itself no longer functions 2. Laptop Charger has inadequate amperage 3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.If it doesn't work, the most likely cause is the laptop charger. Use a new one to confirm: Replacement Acer Aspire 5332 AC Adapter 65Watt 19V 3.42A
Sometimes when the charger connector breaks, it shorts out the charging module on the motherboard, blowing it. It can also blow the external power supply.
If you can find someone else with a similar power supply, try using it. If that doesn't work, you've got bigger issues.
Sounds like the battery might be bad. Try another battery in the laptop and see if it charges. If it does then you know the other battery is bad.
If you try another known working battery and it still wont charge, then try another AC Adapter. If you still cant get the laptop battery to charge then at that point the motherboard is bad because you will have tried another working batter and another working ac adapter.
