Question about Apex Digital GB4308 43" Rear Projection EDTV-Ready Television
Apex projecter 43 inch Apex won`t come on at all,but it will make a start noise.
Buy a new one! Mine won't even make a noise.
Posted on Mar 18, 2008
Apex gb4308 43 inch projection tv
This is not my main field of expertise, in any case here is the link for a solution to same problem and same model. According to expert the problem is related to vertical chip fault.
http://www.fixya.com/support/t142256-apex_gb4308_multi_colored_horizontal_bow
hope it may help you
cheers
Feb 18, 2008 | Apex Digital GB4308 43" Rear Projection...
Samsung Tantus projection TV 40 inches. the problem is that when it has worked for 5 minutes the text and picture is having a trace line that looks like a convergence problem in conventional CRT tv. any...
U have the early warning problems of the convergence problems.Do the manual or auto convergence adjustment until,u can't do it anymore.Replaced all the parts,that make the convergence board to work.
Jun 22, 2010 | Apex Digital GB4308 43" Rear Projection...
Hdmi cable location???
Click HERE to see HDMI Jack image, if it is there at back of TV then OK and if do not, then TV has No HDMI facility.
Apr 28, 2009 | Apex Digital GB43HD09 43" Rear Projection...
43 APEX HA TV
Hi
it is necessary to replace 2 convergence Ic's associated resistors test and repair power supply voltages , then performed a convergence alignment all of this could be around $ 120.00 in parts. go to www.vancebaldwin.com for parts
You rating to my answer is highly appreciate
Jul 03, 2008 | Apex Digital GB43HD09 43" Rear Projection...
Need number of vertical chip for mitsubishi CS2013R
i need a vertical chip for a 43 inch Apex telivision how much are they
Mar 16, 2008 | Televison & Video
Help with my tv
I don't know what you mean by "good". I've worked on this set several times for different problems. What do you need ?
Dec 02, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex 43 inch tv
Convergence is when you aim all three of the projectors, your tv has three, so that the images they produce all line up with each other. This usually doesn't generate a white line across the middle of the screen though, there is a button on the front panel of your set that automatically converges the three projectors, you can try using that.
Nov 06, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex gb4308 multi colored horizontal bow in middle or screen.
This is not an "STK" problem. Your problem is VERTICAL. You need to check your vertical chip for damage CN301 and check around it for any bad parts or loose connections. I've seen loose connections on the chip itself cause it to self-destruct.
Apr 11, 2007 | Apex Digital GB4308 43" Rear Projection...
Apex Digital GB4308
check for cold solder joints @ convergence board, mainly right underneath ic's
Dec 21, 2006 | Apex Digital GB4308 43" Rear Projection...
Apex Digital GB4308 43" Rear Projection EDTV-Ready Television Logo
64 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
