Question about Roper RAS8445KQ Top Load Washer
Belt-how to how do you change belt on roper washers?
  • 105 Answers
Probable pull machine out from wall check underneath for belt
yuo may have to remove motor to fit correct belt to this machine
Posted on Mar 15, 2008
SOURCE:
I have a NEW Roper Washer. It agitates somewhat slowly. My old washer agitated FAST. Is this normal for a Roper?
I would have a look at the cam dogs located in the agitator and the motor coupler or belt if not direct drive. check for loose clutch or slipping tranny. also check for worn agitator spline
agitator coupler bell housing removewasher101-r0vmhnqx3ofapyttmvvmotan-4-9.jpg
Apr 15, 2017 | Roper Washing Machines
My Roper top load washer is making a squealing sound.. Is it a belt?
Most are belt drive on front loaders and on some top loaders but not all. Other culprit can be a dry bearing. Get into it a take a look. A length of plastic hose makes a good stethoscope to pinpoint the noise.
Oct 02, 2016 | Roper Washing Machines
Where is the belt on a roper washer
the top loader dont have a belt they have direct drive they use a transmission,you may be experencing clutch slippage,if that the case you may want to get a new washer
Aug 03, 2010 | Roper RAS8445KQ Top Load Washer
Changing a belt on a washing machine
There is no belt on this machine.
It uses a direct drive coupling between the motor and transmission.
Ope the control console,then remove the cabinet clips to remove the cabinet for access to the motor.
Remove the motor then remove the broken drive coupling(3 parts).
Replace the part and re-assemble the washer.
Jul 25, 2010 | Roper RTW4100SQ Top Load Washer
Belt
You need to check the store for the belt or ask a technician to have it checked and replaced.
Jul 22, 2009 | Roper RAS8445KQ Top Load Washer
Washer runs through the cycles but does not drain
Hi There,
Check the water pump and belt. Let me know if this helps.
Mar 19, 2009 | Roper RAS8445KQ Top Load Washer
Roper Washer doesn't spin
If it is direct drive (no belt) it may be the motor coupling,
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Washer
Sounds like the belt is off / broken or the tub is locked down by something.
Dec 02, 2008 | Roper RAX4233PQ Top Load Washer
ROPER 5 CYCLE HEAVY DUTY. PART NUMBER 3952435
sounds like you have a bad motor coupling(part number 285753a, this machine equivelint to a belt.you tube has a few videos to aid you in this repair, search:: motor coupling whirlpool washer
Nov 23, 2008 | Roper RAS8445KQ Top Load Washer
Changing a belt on roper top load washer
There is no belt on a roper. It called a drive coupler. its direct drive. Go to sears online and go to the parts section and put in your model number. Look at the diagrams and it will show you where it is located (easier to show you than to tell you.)
Nov 16, 2008 | Washing Machines
Roper RAS8445KQ Top Load Washer Logo
62 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
