Question about Canon PIXMA MP600 all-In-One InkJet Printer
MP 600 error 5010
I've had my MP600 since January of 2007 - no problems until this week - I was about to photocopy and after a few moments of 'warming up' all of sudden there was a dreadful 'clicking' sound - something is obviously struggling 'to work' - I had to unplug the machine to get the sound to stop.
After a few moments I plugged in the machine and started it up - the clicking sound started right away - I lifted up the lid and the belt that is just beneath the glass and closest to the front of the machine is the source of the sound - it doesn't seem to be moving, but obviously trying to - I'm not the least bit mechanical, but I think it may assist in moving the light source - which is currently mid way between the right and left sides of the machine. Is this a big deal to fix - ie could I possibly do it? Any help would be appreciated
Thanks
Mike
starcomp
  • 117 Answers
SOURCE: MP600 / Error Code 5010
it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 07, 2008
  • 64 Answers
SOURCE: Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Posted on Sep 24, 2009
sodeep
  • 3267 Answers
SOURCE: Min canon mp600 er låst i
Step 1
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
However
it can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5010 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the gray front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out
Posted on Dec 03, 2010
Rider On Way
  • 1679 Answers
SOURCE: when i turn on canon mp600 all i get is error 5010
* Please rate this solution with Thumbs up and comment to help us improve providing support
Posted on Dec 07, 2010
SOURCE: i baught canon mp 287
we have refilled cartridge CL-811 color and black but not showing level
Posted on Jun 04, 2011
Error code 5010 on cANON MP600 ALL IN ON PRINTER
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request."
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 16, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp 600 error code 6A00
When the printer is not functioning properly you may need to reset it:
1) Press and hold <On/Off> for one second. Display will go blank. (If this does not happen, unplug the printer).
2) Wait approx. 10 seconds
3) Plug in the device - Press <On/Off> if necessary to power on the printer
4) Wait until the device has finished its startup routine
If the problem still persists, your MP600 may need servicing by a qualified technician.
Dec 24, 2009 | Canon Office Equipment & Supplies
Error code 5010
Error Code 5010: Canon recommends resetting the machine. Unplug the power cord for 10 seconds. Then press the power button to turn the printer back on. Wait until the device has completed its cycling process before submitting another job request.
Dec 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma MP600, error code 5010, what does it mean ? Can not turn the printer on for any other purpose, no scanning, copying or printing.
There are a few things you can try:
  1. Power reset; press and hold the Power button until it the machine starts a diagnostic mode; if this doesn't turn on the machine, unplug it for 10 minutes and upon plugging it back in, see if the error reset itself
  2. Unplug all USB devices (including the printer) and reboot the computer. Once the computer has rebooted, plug in the printer, allow it to install (it should install automatically) and see if the error is corrected. Sometimes there can be a temporary conflict and the only way to solve it is to remove all other USB devices (this can work for external hard drives too).
The overall issue with error code#5010 is a scanner malfuntion. If the problem returns, check the ribbon cable as it runs from your scanner to the main logic board. If all is secure and you still have the problem, the printer may need a new logic board.
Nov 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp 600
yes it is possible.
when you give the print command the print dialog box appears select the properties and select one of the options print black and white or print in greyscale.
Apr 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error code 5010
Yes, same thing happens to me...Error code 5010...and flashing green and orange...alternating lights.
I was trying to photocopy (in basic black, not colour). I had a few pages to copy. I got this 5010 Error code after EACH copy!
I had to turn off the printer after each copy and then turn it back on for the next copy. That's not the worse of it.....once I turned the printer back on and hit copy again...the printer took a VERY long time to scan the item for the next copy. It took me a good 40 minutes to copy 15 pages.
Sooooo irritating!!!!!
Anyone know what to do?
I've also had the paper jam on me tons of times. I am really disappointed with this product. I would not recommend this printer to anyone!
Mar 24, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Error Code 5010
it's the printer version of a blown engine(as in your car)..got a warranty, I hope.
start with printer driver updates here
Feb 05, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
127 people viewed this question
old marine
old marine
