Question about Baby Gear
Power windows on a 1994 ford taurus
I can't get my windows to go up or down. power is reaching the relay also reaching the switches i think but I do know that it is almost impossible for electric window moters to burn out at once. how can i get the windows to go up they have been down all winter
My passenger window would go down, but not up. It turned out there was a broken wire that went from the driver's door to the passenger door. It probably broke in the rubber flex thing that goes from the car body to the driver's door. I bypassed the wire with a jumper from the harness in the door to the continuation of the harness on the floor under the door sill on the driver's side. The jumper wire comes out of the armrest and loops around near the hinge area to the floor.
Posted on Oct 28, 2008
  • Anonymous Oct 28, 2008
My passenger window would go down, but not up. It turned out to be a broken wire, probably in the flex rubber housing that goes from the car body to the driver's door and contains all the wires that go to/from the driver's door.
I bypassed it with a wire that goes from the harness inside the driver's door to the continuation of the harness inside the car at a point point somewhere near/under the door sill of the driver's door. This harness continues to the passenger door.
So I have an orange wire coming out of the armrest and looping to the floor. Not pretty, but it gets the job done. It is looped out of the way sufficiently to not be a problem. The only other choice is to try to do surgery on the rubber housing that supposedly protects all the wires that go from the body to the door. The bypass seemed easier.
  • 50 Answers
What you could do is remove the door card and bypass the switch and put the windows up the windows work from the drivers door ie all the power goes through the window switch first then to all other switches like a set of jump leads also check were the wires go to the door you might have a broken wire check the colour of the power and trace it back from the fuse board to the drivers switch
Posted on Mar 15, 2008
SOURCE:
I have a 2002 ford Taurus & the drivers side
There is no way to ever know what a vehicle
repair would cost & only a fool would quote
a price without first diagnosing the issues AFTER
they have things apart
The last shop let you down
Most window problems are a broken window regulator
Could be the switch was worn & was replaced,the relay
if there even is one & windows seldom have a relay,they just
have a circuit breaker for the motor.
The regulator was going & they failed to remove the door panel
to check it
Jul 23, 2013 | Cars & Trucks
Drivers side window (power) quit working. all other windows work fine. what am I looking at. fude? regulator? motor? Is the regualtor and motor together in in this model? 2004 Ford Taurus SEL
Try this....
Open the door, turn the key to the ON position without starting the engine and everything that makes noise is off. Lean down placing your ears close to the bottom center of the door or at the speaker grill. Press the window switch UP and DOWN. Listen for the window motor. If heard the drive is damaged. If not heard, turn key off and locate and replace the relay with one of the other window relays. Check window again. If it works now, get a new relay. Sometimes, removing the motor and turning it by hand will get it working good as new. I have had to do that with Brand New motors! So try it.
If all has failed, with the door panel still off, check for voltage at the motor connector when pushing the window switch. No voltage means its the switch, especially if its a auto down or up switch.
Window fuse's and relay's may be up under drivers side dash or next to battery.
Drivers door window gets used the most so it could be the motor, window switch, relay or fuse.
Could also be a broken wire in the rubber boot going from the door to the body. You will have to eliminate each till you find the culprit.
Aug 13, 2011 | 2004 Ford Taurus
Window relay on 1998 ford taurus clicking sound
check the fuses in the car under the dash on driver side ,only other thing it could be is the power wire in the driver door jam could have a broken ground that is one way it would affect all the windows.
Jan 26, 2010 | Ford Taurus Cars & Trucks
My '02 Ford Taurus SES windows won't roll down
Power windows are wired through their own relay which is usually located in the fuse box. If you don't have faulty switches in your window system I would have the relay checked out.
If you cannot operate any of the power windows and you lost power on all at the one time it is most unlikely that the motors are faulty.
Nov 29, 2009 | 2002 Ford Taurus
Passenger will roll down but not up
When you power up an electric motor with no load it will usually work in both directions... when you put the weight of the window glass on it , thats what shows the motor is weak and in need of replacement... replace the motor and you should be good to go...
Jun 12, 2009 | 2003 Ford Taurus
Ford Taurus Window won't go up
If you are hearing the clicking from the power window relay the only things left would be a break in a wire or a failed window lift motor. If this window only goes down but not up I would inspect the wiring at the door jamb for a damaged wire. If this fails to go either way I would remove the panel, insert test light into the lift motor leads (X2)and actuate the switch, if I get power then I would replace the lift motor. If you get no power in one direction - test switch.
Jun 06, 2009 | 1999 Ford Taurus
What color are power wirers that control the left power window contols on my 2000 ford taraus.
Principles of Operation
Power Window Control
The one-touch down (OTD) power window function allows the driver door window glass to completely lower with one button press. The driver window control switch is hardwired to the generic electronic module (GEM) and door window regulator and motor. When the GEM senses a one-touch down request from the driver window control switch, the GEM supplies a ground to the OTD Relay coil. The OTD relay then provides power to the driver window regulator motor, lowering the window. The OTD feature will function when the ignition switch is in the RUN or ACC position. The OTD feature also operates while the ignition is OFF and the accessory delay time-out period has not expired
May 07, 2009 | 2000 Ford Taurus
1994 ford taurus thermal switch
most of the time it is the intrgrated relay it is a black box above your radiator under the cover i have one it is tested and works good if you want it you can have just pay shipping let me know
Jun 08, 2008 | 1994 Ford Taurus
Baby Gear Logo
196 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
