Question about Initial HDTV-260 26 in. LCD Television
My 19 lcd insignia ns not power on
When I check the voltages on power supply all is in there but I have no audio and any sing of live,do you now the part number of the regulator ,because the number in there is just numbers and no information es available on the web,Actually I now electronic but no really familiar with the lcd tvs..thanks Sergio
Thanks but no thanks
Posted on Mar 15, 2008
Why a 19' Insignia TV wont turn on?
Verify you have power at the outlet, and the TV plug. If no power check breaker. If it was moved recently to anoither location the wall outlet may be on a switched circuit, or downstream of a GFCI outlet.
Aug 20, 2014 | Insignia NS-LCD19 19 in. LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
My insignia model ns-ltdvd26 will cut off on its own. will turn right back on but will only stay on for a few minutes then cuts back off
Power supply board is the cause.The power supply board is shutting down,not giving the right voltage to the tv anymore.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 12, 2010 | Insignia NSLTDVD26 LCD TV
Insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check www.shopjimmy.com they stock boards for many units and I have had no problems.
May 04, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
19" LED TV INSIGNIA HD
I have one of the same tvs. Start by going under menu,setup,tuning band and set it up for antenna. When you get that far put in auto channel search. To see how to get best reception where you live go to http://www.antennaweb.org
Comment if you need any further help
Mar 17, 2010 | Insignia NS-LCD19 19 in. LCD TV
My Insignia NS-27lcd tv won't power on
Could be a dead backlight or inverter board. I would try the power supply as it isn't that expensive. I would buy the power supply from whoever has the best return policy. Best Buy might take it back with no questions asked. This way, if it is not the power supply, you can return it.
May 02, 2009 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
27'' LCD panel compatability
Both power supplies are supplying the same voltages to the circuits but in order to use the one from the NS-27LCD 27" you will need to change the wiring configurations to make it work for the LCT2715..
I could repair the power supply from the LCT2715 for under $90.00 including parts, labor and shipping it back to you.
Let me know if you require further assistance.
Mar 01, 2009 | Televison & Video
Initial HDTV-260 26 in. LCD Television Logo
66 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
