Question about Nikon D40x Digital Camera
Lens slow to focus and makes a bad grinding sound
I have had my 2nd Nikon d40x since August. I had to return the 1st one due to the same problem that I am having with this one. I used this d40x all Fall to take beautiful pictures of my sons baseball team. I pulled it out to use it again for the Spring Season and the lens is sluggish to focus and makes a clicking/grinding sound. Since this is the second time this same thing has happened I am concerned that the lens gets dirty easy. I took it to a local camera store and they took a look into the camera body and thought it looked clean. Has anyone else had this same problem? At this point since it is under warranty I am sending it to Nikon to check out. I am concerned that this is going to happen again since I use it at the ball fields where there is always dust. I have never dropped the camera or lens or have changed the lens other than at home or in a protected environment.
    Problem Solver:
  • 11 Answers
It sounds like a lens problem, not the body's. Have you tried it with another lens? If you don't own any lenses, go to a camera store and ask to try out one of their lenses, if the problem goes away then you know what is causing it. The lenses usually have 5 year warranty.
P.S. You should consider the option of buying another lens for the baseball games that has high zoom and VR.
Posted on Mar 19, 2008
Wife dropped nikon d40x on concrete...will only shoot on manual. Lens will not autofocus.
Lens motor(inside the lens) could be damaged already. The D40x focusing system is dependent on the lens, just like any other Nikon Dx camera except for the ones that has built-in motor to its body, e.g. D90, D7000. Try a different lens, most likely it should work
Jun 17, 2011 | Nikon D40x Digital Camera
When trying to take a picture the lense moves back and forth trying to focus. When it finall stops the subject is out of focus. There is a grinding sound as it tries to focus. Some times the picture will...
It sounds like you need a new lens. This particular camera does not have an autofocus motor built in, which means it can only use lenses that have a motor already built in. Look for any Nikon lenses that have the AF-S in their name.
Amazon Search for "Nikon AF-S":
This is also a good "general use" lens:
Hope this helps.
Feb 28, 2011 | Nikon D40x Digital Camera
Nikon D40 Not focusing, then not shooting
What lens do you have mounted?
The kit lens is generaly made from plastic, and if dropped or hit, the focusing part may break. Therefore it's a lens problem. You need to get it to a specialist to fix it. I own a D40 with kit lens for 2 years now and did not have such problems with it.
Apr 06, 2010 | Nikon D40x Digital Camera
My Sigma 70-300 doesn't workin autoFocus mode. It
That lens is not an AFS type lens. The D40x camera only uses AFS compatible lenses. You could still mount and use it in M, but it will never give you autofocus or TTL flash.
Oct 14, 2009 | Sigma 70-300mm f/4-5.6 DG Lens
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
Jul 14, 2009 | Nikon D40x Digital Camera
Lens will not auto focus wit my Nikon D40x
That lens doesn't have an internal focusing motor and thus will not autofocus with the D40x. Nothing is broken.
Apr 11, 2009 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
No autofocus
We tried the same lens on another Nikon (D90) and auto focus did not work.
We mounted a new set of lens on the original D40x, and it worked.
Turns out the 2 year Nikon lens (18mm-135mm) was bad. Nikon lens have a 5 year warrantee. The lens will be sent back to Nikon with no service or shipping charge.
Dec 08, 2008 | Nikon D40x Digital Camera
Nikon D40x AF-S Nikkor 18-55 mm 1:3.5-5.6 GII ED Lense Trouble
I've found the same thing with my D40x and the 18-55mm AF-S lens. I took a really close look at it and found that the mount on the lens is badly worn on all three of the bayonet tangs and one is cracked at the base. What happens in my case is that the lens has movement when mounted on the camera - just enough to stop the contacts from mating properly. Hence, no photos. Am taking it to Nikon to get it fixed. I suggest if this is your problem, that you take it to the repair man.
Apr 14, 2008 | Cameras
Nikon D40X stopped auto-focusing yesterday
I had the same problem. My issue was with all my lenses. I solved it by going to the menu and selecting the custom setting menu (pencil icon). Then from the right menu select the AE-L/AF-L and press OK. Then make sure it is set on AE/AF Lock. Presto...all my lenses worked on auto-focus.
Feb 24, 2008 | Nikon D40x Digital Camera
Nikon D40x Digital Camera Logo
90 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
