Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer 1015 OMT Disc spins, then stops....
I have a 1998 Wurlitzer OMT that won't play any discs. It places the discs correctly on laser, and starts to spin, but then stops, tries again then stops again. What gives?
Also, I don't know if this is related but when the Juke Box power ups the display always reads 2222. I have tried to power down and up several times with no luck. Thanks in advance.
John
    Problem Solver:
  • 5 Answers
Spoke with "Doctor Jukebox" from Folsom, CA about a similar problem I had. You can find him on craigslist.
I did NOT have the "2222" display issue.
Root cause: The laser isn't "seeing" the CD and interprets inability to see as being the end of the track, therefore, puts the CD back into the carousel.
Solutions:
1) Clean the lens. Be careful to use an appropriate lens cleaning solution. The lens is made of plastic and may cloud up if a harsh solution is used. Use a Q-tip dipped into the cleaning solution and gently clean the lens using a side-to-side motion, not a front-to-back motion. Wait for a bit until the lens is completely dry, then try playing a CD. (note: this fixed the problem for me)
If that doesn't work...
2) Replace the laser module. It's easy to remove with a torx. Be gentle when disconnecting and reconnecting the ribbon cable and/or other connections so you don't bend the leads. Laser modules cost a few hundred dollars, so try Solution 1) above before replacing the module.
Posted on May 22, 2010
    Genius:
  • 1,550 Answers
Give a good clean to the laser if don´t work change tthe laser.
Posted on Mar 17, 2008
Can't play discs
i can send you the manual to fix it
Sep 18, 2012 | Wurlitzer Jukebox 1015 One More Time...
I purchased a used Wurlitzer 1015, question When selecting number 51 is a code number 82 and does not play can you explain me this, what the problem is thanks
The number of Cds in the carousel can be set on the Credit unit to stop it playing fresh air if for example you only have 50 Cds and not a whole 100. Sounds like yours is set to 50 so won't play anything over 50.
I 'think' this is what you do.
On the computer credit unit...
Service Switch ON...Press LT button.
Press 5 on the keyboard once.
Enter 0000
Service Switch off.
Press LT or turn machine off/on.
Aug 03, 2011 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer OMT, takeout arm continues to cycle all the time
There is a white bracket on the far side of the gripper arm which comes loose so it doesn't click the microswitch beneath it. To prove this press o the bracket when the arm is over the cd magazine and it will stop.
Oct 11, 2009 | Wurlitzer Jukebox 1015 One More Time...
Im looking for laser for model omt cd 100
You are looking for a CDM12 or CDMPro or CDM Pro2
Mar 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
654 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
