GE top loader GJSR2130 does not spin water out of clothes - all else working fine.
  • 105 Answers
Blockage in the pump a possibility
or bowl is stuck with obstruction
Posted on Mar 15, 2008
SOURCE:
GE front loader spins slow
need the Model number to help you find the white tag and add the model number it inside the front door frame
Feb 03, 2018 | GE Washing Machines
I have a GE Eterna top loader washer. It appears that is not spinning during spin cycle (damp clothes and softener not dispensed). Spin cycle runs with no load. How can I troubleshoot further?
Perhaps you machine is full of water and therefore restricted by the excess water in the tub, perhaps try draining the machine first then try again. it could be that your pump in ineffective .
Sep 19, 2016 | GE Washing Machines
I have a GE Top Loader and it will wash clothes, but it will not spin all the water out of them. Checked the hose and the drain pipe-all are clear. No clogs. not sure if the motor is spinning as fast as it...
loose belt if it has one could be a direct drive ???? ck the inner tube could have a sock stopping all the water coming out water pump going out bad transmission
Mar 16, 2011 | GE WJRR4170E Top Load Washer
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
GE Top Loader Washer, spin cycle not working.
When you close the cover, there is a pin push the switch down, check that one, see if it is help.
Jun 02, 2008 | GE WBSR3140DW Top Load Washer
GE 1996 top loader agitation but good spin cycle
check the motor, the timer,the water level indicator in side the machine on the basket it will have a tube with a little box attached to it. It may be clogged or malfunctioning.
Apr 27, 2008 | GE WDSR2080D Top Load Washer
Have GE GJSR2130 or
is this machine top loader or front loader
Mar 15, 2008 | Washing Machines
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
254 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
