Have GE GJSR2130 or
Have GE GJSR2130 or GJXR2130 - works fine except it does not spin water out of the clothes. Pump and everything else seems to be working fine. About 5 years old.
  • pgraves Mar 15, 2008
    The above machine is a top loader - cut-out switch on lid "clicks" ok, motor agitates, but will not spin
  • pgraves Mar 16, 2008
    Motor runs on wash cycle, but not on spin cycle, lid switch checks out OK,
  • 105 Answers
Is this machine top loader or front loader
Posted on Mar 15, 2008
  • william mikkelson Mar 15, 2008
    is the motor running when the machine in spin cycle and if it is
    does the adjitator moving?
  • william mikkelson Mar 16, 2008
    so if machine works on wash fine are all the selecta switches set to normal cycles
    if so and everything seems fine the the timer coulld be faulty
When i put my machine on to spin the clothes are coming out very wet, I have cleaned out everything, everything seems to be working properly, The pump is fine, Can you tell me what is wrong I use onl
Depends how old your machine is Sounds like your motor maybe wearing out. Does it make any noises. Make sure your not putting in to many clothes weighting it down. Try spinning a very little load see if they come out ok. If not MOTOR.
Jan 21, 2015 | Washing Machines
GE washer WHSR2070VWB about 9 years old does not spin dry clothes. All of the cycle works except the final expulsion of water
If the cycle stops when it is supposed toi drain , that means that there is a problem with the drain pump.
Oct 12, 2008 | GE Washing Machines
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Wprb8050d0ww does not drain, clothes very wet
eric it seams that its draining ok?thats important.must happen in a certin time frame to get clothes dry.also this thought comes to me check between the tubs with your hand thru the top.if clothing got there it couldnt spin well.but as a repairman i have replaced more ge motors than boards.god bless i hope that helps
Jan 03, 2009 | GE WPRB8050D Top Load Washer
Final Spin
could be a clogged water pump. check the filter/pump for dirt and small items, socks, pins, coins,
tnx 4 using fixya,
drcool
Oct 11, 2008 | GE WBSE3120B Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
GE top loader GJSR2130 does not spin water out of clothes - all else working fine.
blockage in the pump a possibility
or bowl is stuck with obstruction
Mar 15, 2008 | Washing Machines
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
