Computer moniter On the screen, a message appears saying that "Not Optimums and recommended 1280 x 1080." when i turn on the computer. It does nothing else except display tha message.
  • 88 Answers
Press F8 during startup to show the boot options. Boot to VGA mode (if available) or safe mode and change your resolution in windows to the recommended 1280X1080. To do this in XP just right click on the desktop and select 'properties', click on the right-most tab and move the slider.
In Vista this would be right-click desktop, select 'personalise', click 'display settings' and move slider.
Hope this helps,
erch.
Posted on Mar 15, 2008
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Moniter
Right Click on your desktop, then select properties. Then Advanced tab. Then you need to change your screen resolution. There will be a little slider that you can move left or right. Move it until you get it to the 1280x1024.
Sep 22, 2007 | Samsung SyncMaster 710VT TFT LCD Monitor
LG Flatron E2042. Brand new. New CPU. Windows 7. I plugged in my new monitor today. Does not turn on automatically. But when I do turn it on I get an error message. D SUB POWER SAVING MODE and tur
Your new moniter may not be compatible with your computer. I have an Emachines that won't take a flat screen. I have to use a big bulky moniter because it says not connected even thought the hookup fits the back of the tower. That might be your problem. Did your old moniter work correctly?
Nov 15, 2012 | Computers & Internet
The computer will turn on but the screen stays black and does not appear to be responding to anything. It will turn off and on idicated by the light on the power button.
check whether the moniter cable is connected to the cpu or nor.it nothing appears on your monitor not even cursor.then there is fault in cable connecting cable
Dec 29, 2010 | Computers & Internet
Processor continues to run and my moniter screen says power save mode before it turns completely black
Sounds like a bug in your Monitors wire. I would recommend you to clean the connectors of Monitor wires and then insert them to sockets in your computers back ports tightly. That might solve your problem. If you still have problem then i would recommend you to repair your monitor's Data Wire, that wont cost you much.
Good luck, and have a nice day ! =)
Dec 17, 2010 | Computers & Internet
My computer says power saving mode
does it shut down when the message appears?
Jul 24, 2009 | Gateway FPD2275W LCD Monitor
Moniter says no signal
You may need to replace the moniter cord or check the video card on the computer.
May 31, 2009 | Acer Aspire™ T180 PC Desktop
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Speakers killed my moniter
Well as you have already tried disconnecting the peripherals from your computer, and tried restarting the computer too which did not help you, it sounds to be an hardware issue with the monitor. However if incase you have not tried this, you can disconnect the monitor completely from the tower, power on the monitor, if it powers on and you get a message as no signal, your monitor is working good. If not replace the monitor. If the message appears on the monitor screen, disconnect everything from the tower, push and hold the power button on the tower for a minute. Connect just the monitor and check for any display. If you do get display, thats good, connect one device at a time and check to see if the display appears.
If theres no display with just the monitor connected, the issue would be with the graphics card. You may need to replace it or get the system repaired.
May 27, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
