Question about Dryers
HELP!!!!! Need to know how to replace the heat relay on a maytag se1000
    President:
  • Dryers Master
  • 2,651 Answers
Just looked up the diagram wasnt real clear as to how to get to the relay. I would imagine that dropping down the front acess panel (angled toward youbeteen the wshe rand dryer) will gain you acees to the compartmant in which its located in the right rear of. However the picture indicated a small acess hole on the rear of hte unit it self that might be a a more feasable entry.(although i believe that this is where the main wiring is located(wasnt pictured)
Posted on Mar 15, 2008
SOURCE:
Maytag se1000 washer has no plug in wire. How do I make sure that a new plug is wired correctly?
on the back washer plate there should be a wiring diagram this will show the connections. Hope this helped tim
Aug 28, 2010 | Dryers
Maytag SE1000 Series 07 dryer wont heat
You need to have 220-240 or so volta ACROSS the two terminals on the element...the 125 can feed across and can be the same leg on both sides...
Check out this tip also..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 22, 2010 | Dryers
Maytag MDE9206AYW will not heat. What do I need
I assume it is a gas dryer. Turn it on and if no clicking sound is heard within 30 seconds the spark ignitor needs a replacement. If it is an electric dryer you need to check the relay for the burner system first
Apr 16, 2010 | Maytag MDE9206 Dryer
Maytag dryer drum not turning - suspect belt - don't know how to get to it.
take the back off the dryer, take the back support rod loose, that's the thing that hold the back of the drum up. Then slide the belt back over the drum, the belt rides right in the middle of the drum motor should be in the bottom right hand corner.
Jul 04, 2009 | Boss AUDIO SYSTEMS SE1000 Car Audio...
Maytag SE1000 Dryer - high pitch buzz, then total non-start
Often, after a power surge that exceeds the parameters of surge suppression devices on the circuit board, the unit will do this. You will more than likely have a failed control board now and will need to replace it.
Dec 03, 2008 | Dryers
Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Jul 05, 2008 | Maytag LSE7806A Top Load Stacked...
sounds like the brake is not engaging properly(locks the tub for agitiation) wouldn't say transmission just yet, don't know the age but probably a few hundred dollar repair, i would recommend a maytag guy to do the repair, requires special brake tools and such,
Mar 06, 2008 | Washing Machines
Dryers Logo
117 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
