Question about Brother MFC-8460N All-In-One Printer
Receive Fax does not work
I've downloaded all the software but I can't get the receive fax function to work. When I run diagnostics it tells me that it failed.
  • 47 Answers
Are you able to send, and do you have dial tone?
Posted on Mar 15, 2008
SOURCE:
Fax will not receive faxes
You have to go through your menu to fax functions & change it from manual to automatic.
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
When I try to send a fax the machine gives a message cannot receive or send fax. I am getting a dial tone through port 2 still. If bad modem can they be changed in this model?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi,
In order to find the solution to this issue, you need the fax number for another fax machine that is operating correctly with which to send and receive faxes. After trying each of the following solutions, try to send or receive a fax from this other fax machine to test if the issue has been resolved with your HP fax product. The other fax can be in the same building, on another telephone line, or at another location with someone who can assist. It can also be helpful to call the person or company that is sending the fax. That party can offer information about how that fax machine behaves when sending a fax. This information can be valuable in determining the nature of the issue.
There are several possible solutions to this issue. Start with the first solution and then continue with the other solutions in the order presented until the issue is resolved. When the issue is resolved, there is no need to continue troubleshooting.
Solution one: Run a fax diagnostic test
Run a fax diagnostic test to make sure that the HP fax product is set up correctly.
Load letter or A4 unused plain white paper into the input tray.
on the product control panel, press the setup button ( ).
Use the down arrow key ( ) to select Tools and then press the OK button ( ).
on the Tools menu, use the down arrow key ( ) to select Run Fax Test and then press the OK button ( ).
Review the results of the test.
If the result of the fax diagnostic test is All Pass ,
Reinitialize the fax
1. With the HP fax product turned on, disconnect the power cord from the back of the HP fax product and from the electrical outlet.
2. Connect one end of the telephone cord to the telephone jack and then connect the other end of the cord to the port labeled 1-Line on the back of the HP fax product.
3. Reconnect the power cord to the back of the HP fax product and then reconnect the power cord to the electrical outlet.
4. After the HP fax product reaches a ready state, try to send and receive a fax again.
If this works GREAT!, if not let me know....JCE
Apr 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
I can send faxes from my HP J3640 but I can't receive them. The instructions mention turning on "auto-answer", but there is no button or nothing in the menu for "auto-answer". How do I turn on auto-answer?
Issue The product cannot receive a fax, but it sends faxes successfully. All other functions work correctly. Usethe following solutions in the order presented to resolve the issue.When one of the solutions resolves the issue, there is no need tocontinue troubleshooting. Solution one: Run a fax diagnostic test
  1. On the product control panel, press the Setup button (c01461502.gif).
  2. Press the Right Arrow button (c01185072.jpg) to select Tools.
  3. Press the Right Arrow button (c01185072.jpg) to select Run Fax Test, and then press OK. The fax diagnostic test prints.
  4. Review the results of the test.
    • If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report totroubleshoot the issue. This report is specific to your product andfaxing environment, so try the solutions on the report before tryingthe next solution in this document.
    • If the test does not show faxing issues and solutions, the fax test passed. Continue to the next solution.
Solution two: Test the receiving function Follow these steps to make sure the receiving function works correctly.
  1. Makesure the originator of the fax has the correct fax number for yourproduct, and then ask that person to send a test fax to your product.Watch the control panel display and listen to the sounds the productmakes.
  2. Review the results of the receiving function test:
    • If the product receives the fax correctly, you resolved the issue. You do not need to continue troubleshooting.
    • If the product does not ring or does not answer the call from the other fax machine, ask the originator of the fax to send the test fax again. If the second try fails, go to Solution eleven in this document.
    • If the message on the control panel reads ' Answering' and does not change to ' Connecting', the product is not detecting the other fax machine. Go to Solution eleven in this document.
    • If the product rings briefly, and then stops, another device answered the call. Continue to the next solution to continue troubleshooting.
Solution three: Check for conflicting telephone services Many telephone companies offer services that prevent unwanted calls. The following services might block incoming faxes:
  • Voice mail
  • Privacy block
  • Security screen
  • Anonymous call rejection
  • Privacy manager
  • Any other service that screens or intercepts incoming calls
If any of these services are on the telephone line connected to theproduct, contact the telephone service provider for its recommendedsolution. A distinctive ring service, if it is available from the telephone service provider, often resolves this issue. Solution four: Use an analog phone service HPdesigns Fax and All-in-One products to work with analog telephoneservices. These products might experience some difficulties whenconnected to phone lines with digital services. For best faxingresults, connect the product to an analog telephone service. To obtain digital services information or support, contact the telephone service provider or your system administrator. Solution five: Check the fax connections
Jan 03, 2009 | Office Equipment & Supplies
Holding documents in Memory to retrieve at a later time
its called receive to memory,
at night tell them to press
function-8-5-start-2-start-stop screen will say receive to memory
in the morning tell them to press
function-8-5-start-1-start-stop
Dec 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
CANNOT RECEIVE A FAX
Slim1234,
          A multitude of problems might cause receive problems, and the User's Guide has no "receive Problems" section under troubleshooting - so here goes:
        If I had to guess right off the bat, your problem is probably
that the FAX is in "FAX Storage" mode, and is out of memory.
In this mode, it will print FAXes until it runs out of memory.
See problem "g" below.
   a. Voice mail active on the line - if voice mail and FAX-2820 are
       set to answer the line on the same number of rings, there's
       no way to know which will answer first.
   b. Voice mail active on line - if voice mail is set to answer in
       fewer rings than the FAX, then the FAX will always lose
       (but you'll have no problems Xmitting).
   c. Call Waiting active on the line - the call waiting "boop" will
       kill incoming FAXes (and outgoing FAXes too, but your
       personnel will retry the outging ones until they succeed
       and you may only hear complaints about incoming FAXes).
   d. Your FAX-2820 is set to "Manual" or "External TAD" mode.
       Reset it to "FAX only" or "FAX/Tel" mode (depending on
       your office use of the FAX telephone line).
       How to do this: Menu/Set,0,1 <up/down to select mode>
                              press Menu/Set.
   NOTE: your LCD display tells you your receive mode:
       Mine says "Sleep 22:08 Fax", telling me I'm in "FAX only"
       mode, and its 10:08 PM.
   e. You've set the FAX to RING DELAY - if so, the FAX
       must win. Setting ring delay to 00 tells the FAX to answer
       the line silently (an advantage for a busy MD's office).
       How to change this: Menu/Set,2,1,1
       Ref: FAX-2820 User's Guide p.4-2
   f. You dont have a shared (FAX/human) line set to
     "Easy Receive"; if someone answers the call and
      Easy Receive is off, then they need to press START on
      the fax machine front panel or dial *51 and hang up.
      How to change it: Menu/Set,2,1,3
      REF: Fax-2820 User's Guide p. 4-2
  g. You may be set up for "FAX storage."  In this mode, received
      FAXes will be stored (and printed) until you run out of
      memory (quickly done on a Brother FAX-2820), then you
      get nada (but sending FAXes still works).
      How to reset this: Menu/Set,2,5,1 <up/down>
      REF: Fax-2820 User's Guide p.6-2
  h. You may have set up FAX forwarding.  In this mode, sending
      FAXes will work fine, but all incoming FAXes willl be sent
      to another telephone number.
      How to turn it off: Menu/Set,2,5,1 <up/down>
      If this laundry list of (sending OK, Receiving dead) scenarios
 doesn't resolve the problem, email your FAX number to me
and we'll do some cross-country FAX debugging.
                                  Dave in tech support
                                  [email protected]
P.S.
      The above features may have been set remotely by a
   nefarious (or somewhat knowledgeable) individual - remember
   that a little knowledge is a dangerous thing (even for
   FAXes). See (extensive) remote programming instructions
   on p.6-6 of the User's Manual.
        To print out the caller ID list - and possibly find out the
   source of the remote programming:
   Menu/Set,2,0,3 <up/down to "print report">, Menu/Set,
    Start, <Caller ID report prints>, Stop/Exit
   Ref: Brother Fax-2820 User's Guide p.A-3
Dec 20, 2007 | Brother IntelliFax-2820 Laser Fax
Receive fax on the fax system as well as your PC
If you change the number of rings on the fax machine to more than on your PC, your PC should receive the fax first and accomplish your goal.
Dec 19, 2007 | HP LaserJet 3500n Printer
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother MFC-8460N All-In-One Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
