Question about RCA D52W19 52" Rear Projection Television
Rca wont turn on
I read you fix and checked 2200 35v cap.i went to radio shack they had one that had wire out of each end.it will not fit.my question is when i removed the cap it says 2200 16v.i have a 2200 35v out of a dual tape deck will this work ?just trying to make friday night more interesting.thanks!
  • 61 Answers
As long as its a 2200 cap and the voltage is above 16 it will work fine.
Posted on Mar 30, 2008
Input fitting on headphone has broken,can this be fixed?jack wont stay plugged in
Hello. Yes it can be fixed. Take your headphone to any radio shack store and show it to one of the technicians there. They will show you the component you need to make the repair. Many times, a dab of one minute clear epoxy will mend too. Regards, Joe
Jan 09, 2010 | RCA WHP160T Consumer Headphones
Blows fuse
check to see if any transisters or anything have black around it and check if any are loose on the board
Jan 03, 2010 | RCA F27442 27" TV
RCA rear projection monitor that won't turn on
I fixed four of these TV's, one a few days ago.
All three sets had two bad capacitors.
The caps are on the main board towards the front of the set, on the left side.
One cap is 2200uf 16v, and is located inside of a "U" shaped heatsink. The other cap is 330UF 16V, and is outside of the heatsink, to the left of the heatsink. Both caps will look bulged on the top. You can probably get these caps at radio shack for a few dollars. I buy my parts from Mouser electronics.
If you can see that the caps are visually bad, then replacing them will probably fix the set.
Good luck,
Dan
Nov 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV WILL NOT POWER UP IT ONLY DISPLAYS 10 BLINKS
I fixed three of these TV's, one a few days ago.
Good luck,
Dan
Oct 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w19 chassis itc222
The fuse rating should be on the metal side of the metal ends of the glass fuse. Very hard to read amps and rating, may need a jewelers lupe. Or take the remains to Radio Shack.
Feb 15, 2009 | RCA D52W19 52" Rear Projection Television
RCA Model: P52738wk
YES CHECK FUSE AT REAR PANEL - MUST REMOVE THE FOUR SCREWS FOR ACCESS THEN ON THE TOP OF THE PLUG CONNECTIO N YOULL SEE FUSE - SEE RADIO SHACK.
Feb 14, 2009 | RCA P52937 52" Rear Projection Television
My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Mar 05, 2008 | Philips Magnavox 42MF521D/37 Television
Hook up problems
either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Jan 02, 2008 | Sony STR-DE835 Receiver
Akai lct3201 power problem
I fixed my Akai LCT3201AD in about 30mins. using 3 small parts from Radio Shack. Once I got the back off, I found the power supply board (PSB), mine was part# MLT-169B rev1.2. I looked at the capacitors (caps.) first, because they are usually easy to diagnose. I noticed the caps. bubbled out on the top of the board (where all the cables connect to it). There is 3 of them in a row, positioned between the two large heatsinks. My guess is that the heatsinks are generating a LOT of heat over time, because of bad ventilation, and causing the caps. to fail.
I went to Radio Shack and found 3 caps. (only had 3 in stock). The original ones were 16V-1000uF, Radio Shack only carried 35V and 50V in the 1000uF caps., so I bought the 35V ones and headed home, I removed the old caps. from the board, and installed the new ones. The 35V caps, are a little bigger, so its a tighter fit on the board, be careful. It took longer to remove the back from the TV than it did to do the soldering. YouTube.com has excellent videos on how to de-solder caps. on PSB's.
Total money spent on repairs:
$1.59 ea for 3 Caps. (part# 272-1032) $4.77
$2.99 for new soldering iron tip + $2.99
$1.00 donation for St. Jude's + $1.00
Total including tax $9.30
So for less than $10, I did a repair that my local TV repair shop wanted $575 for. Online stores want anywhere from $100-$275 for a PSB. If I get another 2 yrs out of it that's well worth $10.
Nov 22, 2007 | Akai LCT3201AD 32 in. LCD Television
RCA D52W19 52" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
