Question about GE Advantium SCA2001BSS Microwave Oven
Ge avantium changing magnetron
How do you get to the magnetron. it seems impossible to remove. any tricks?
  • daniel89 Jul 13, 2008
    Where can I find dis-assembly instructions? Thanks,in advance!
    Dan Courtney
  • GE Master
  • 9,098 Answers
Usually you have to remove the outer cover of the microwave, and if it's an over the range model, it will have to pulled down from the wall.
If you don't have your installation instructions, you can download them here.
FYI, these models usually have a 5-year warranty on the magnetron.
We have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
GE Avantium 120 Oven microwave/convection Door sticking. How to fix out of alignment?
Remove outer cover, exposing hinges. Loosen mounting screws and adjust as needed.
Nov 12, 2017 | GE Microwave Ovens
Hi, I have a GE JES1334 1100 Watts Microwave Oven, it can be power on, but doesn't heat, should I change any part to get it back to work? Thanks!
Hello, W/D here.
There are many variations of your model. Check the fuse first.That's the most common failure, and the cheapest to fix.
I checked the price of magnetrons and, if that is what is wrong with yours (which it sounds like), the cost of the magnetron is more to replace than the price of a new microwave. ($162 vs. $115), plus shipping if you bought the part on-line (I checked Appliancepartspros.com), and add in labor if you have someone else do the work. Your best bet is to take it somewhere and get a free estimate for repair, and decide from there. It may not be the magnetron, but it's impossible for me to tell from here.
Best regards, --W/D--
Feb 10, 2011 | GE JES1334 1100 Watts Microwave Oven
I have a GE Spacemaker and it is about 9 yrs. old. Sometines it heats; other times it doesn't. I change settings and sometimes that works. Is this something that can be repaired or is this a sign I need...
When the microwave is not heating, that means the magnetron is not working. This is what provides the heat to the microwave. I do believe the magnetron has a 10 year warranty.
If you wish to replace it, here is how:
  1. Unplug Microwave at least few hours before
  2. Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
  3. Remove top cover of Microwave
  4. Make sure to keep screws correctly in a place you remember what goes where
  5. Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
  6. Remove other panels around magnetron part
  7. You need to remove lot of connecting wires, should be careful to note down what goes where
  8. If possible take digital photos to refer back when you put everything back together
  9. You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
  10. Now it should be easy to remove magnetron
  11. Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
  12. Make sure put all wires properly back
  13. Now put transformer back and screw it
  14. Put capacitor panel in place and screw it
  15. This might be a good time to test the Microwave to make sure it works fine now
  16. Now cover the top panels and start to screw everything
  17. Once everything assembled put the Microwave back above range put screws from top
Sep 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My ge countertop microwave suddenly became very hot and seems totally dead
Chances are the magnetron overheated and the thermal protector (thermal cutout or thermostat) on the magnetron tripped and interrupted the power.
This may be due to a blocked air vent, clogged filter, blocked outside vent, failed internal cooling fan, or failing magnetron.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille or elsewhere, and it is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
Warranty terms are detailed in your owner's manual.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Dec 25, 2009 | GE Countertop Microwave Oven
Smelled like something was burning and stopped heating. Turntable and lights work
I have GE microwave with a failed Magnetron. It is emitting large sparks. Upon removing the magnetron I found that the sparks left residue where they are leaking from the cylindrical shaped piece on the end of the Magnetron.
The Magnetron is under warranty.
BUT
GE WILL NOT HONOR THEIR WARRANTY AND SEND A MAGNETRON.
GE HAS SENT OUT HUNDREDS OF MAGNETRONS TO CUSTOMERS - SEARCH ONLINE TO SEE THIS IS TRUE.
I called GE PARTS, GE support and GE consumer relations department. They changed their policy two weeks ago and require a service technician to replace the part.
THE COST IS $220 FOR THE REPAIR TECHNICIAN.
Since I already removed the part the service technician would have to put in 3 screws and plug in the cable...FOR $220...I PAID $229 FOR THE MICROWAVE NEW!!!!
DO NOT BUY GE.
DO NOT BUY GENERAL ELECTRIC.
GE DOES NOT SUPPORT IT'S WARRANTIES UNLESS YOU ARE WILLING TO PAY THE SAME AMOUNT THAT YOU PAID FOR THE PRODUCT!!
Further research:
GE Microwaves can spontaneously turn on and start a fire - see Consumer Reports web page here:
http://www.consumerreports.org/content/cro/en/consumer-reports-magazine-march-2012/kitchen-fire-safety.html
Further evidence GE retroactively changing their warranties:
http://www.complaintsboard.com/complaints/ge-california-c197693.html
Nov 30, 2009 | GE JVM1650 1000 Watts Microwave Oven
Magnetron dead
THEY RUN ABOUT 125-150 DOLLARS. YOU CAN TRY WWW.REPAIRCLINIC.COM
Apr 27, 2009 | Microwave Ovens
Please Help my GE Microwave produces no heat!!
Most of the time it seems to be the magnetron. The Magnetron is what heats the food, when you remove the magnetron sometimes you will see signs of wear like a black or brown spot on the tube sometimes there is even a hole burned through. A cheap place to find these part is Global Micro Parts in Dallas TX. Usually Magnetrons are about $30 - $45 and shipping is only 7.95 there web site is www.allapplianceparts.com
Oct 26, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE SCA1001 DEAD
Yes, there are several thermal cutouts in Avantium ovens.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
You may also have a defective thermostat or a bad connection at the thermostat.
May 05, 2008 | GE Advantium SCA2001BSS Microwave Oven
Ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Jan 22, 2008 | GE JVM1650 1000 Watts Microwave Oven
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
489 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
