Question about Brother IntelliFAX 2800 Laser Fax
Fax machine getting erroe77
Getting message unpulg machine then call brother
error77
    Scholar:
  • 78 Answers
Fuser or overheat error. Menu,*,2,8,6,4 quickly in that order will give access to maintenace mode (lights will flash once your into the mode). Hit 01 to reset the machine. If this doesn't work you have a major problem with your fuser unit and it will need to be replaced. DO NOT DO THE ABOVE PROCEDURE MORE THAN ONCE AS YOU WILL START TO MELT STUFF IF THERE IS A MAJOR PROBLEM.
Posted on Mar 16, 2008
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
Poor Line Condition message
If your fax has a handset listen to the dial tone and make a call if the connection is poor call the phone Co.
DickyO
Nov 09, 2009 | Brother IntelliFAX 1170 Plain Paper...
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Answer phone message
I would like to change my brother fax -T94 machine from French to English and also to set up an answer phone message on it. Thanks Denis,
Apr 01, 2009 | Brother FAX-T94 Plain Paper Thermal...
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
I have a intellifax 4750e and getting error code 77 unplug and
We have a Brother 4750. Experienced a power outage. Now it's giving a message of "error77" what do we do?
Dec 20, 2008 | Brother Office Equipment & Supplies
Brother IntelliFAX 4100
First plug in a normal tone tellefone into the wall jack that your fax is using.Make sure you get the fax signal from the faxnumbers you struggling with.If you can hear any line noises on the line it may be the problem why you cant get a fax trough.Make sure your fax is set on the correct county code-tone or pulse.
Oct 29, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother Fax-t74
I have found a link to an online version of the manual.
Brother Fax-t74 Manual
Sep 30, 2008 | Brother FAX-T74 Plain Paper Thermal...
Error77
okay well it sounds like you have a problem, hehe.
i can only help you if you give me the make and model and tell when it comes up with the error code. also start by unplgging the machine for 2 minutes the look at you watch to see when in the warm up cycle you come up with the error code. if it's within the 10-30 sec. of pluging in/turning on. then it's a drive/board problem or many others so time it and i can be more helpful.
mikey
Mar 13, 2008 | Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
