Question about Acer Aspire 3680 Laptop
Broken wireless button
The button in the front of my laptop is broken...isnt there a way i can connect to the internet without using it? maybe a function combination key?
    Scholar:
  • 105 Answers
If not wireless can often permanently be set to on in the bios - enter the bios [f2 or del at start up] and select the wireless permanently on option. Take care as changing bios settings can make your laptop unable to boot.
Posted on Mar 15, 2008
  • 55 Answers
Most laptops use the combination hold down FN then press F2 to turn it on.
SOURCE:
Whenever i connect ethernet to my laptop the internet does not access ,what maybe the problem
Do you have both the wired and wireless network adapters enabled? You should be using only one or the other.
Disable the wireless adapter while using LAN cable to connect internet.
Also run and post the full results of "ipconfig /all" (without quotes) via the Command Prompt.
Thanks.
Sep 08, 2018 | Internet Computers & Internet
My lap top isnt set up for wireless connection to internet
Connecting laptop/computer to wireless router
If you have a wireless router and it is connected to the DSLor cable modem and Internet then -To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
Jun 16, 2012 | Samsung Computers & Internet
I have purchased (Sept 2011) a reconditioned HP NC4400 (without instruction manual) that will not connect to my existing Internet (wireless). I used Help (Intel (R) Wireless Troubleshooter) on the laptop...
Hi Steve,
The wireless switch would absolutely have an effect on whether your WIFI was ON on your laptop. The following link shows a diagram of your laptop:
http://h18000.www1.hp.com/products/quickspecs/12448_na/12448_na.HTML
It appears that it is a button on either the left edge of the laptop, or possibly above the keyboard. Press the button and ensure your WIFI LED (front-left edge) should be lit. Then, try connecting to your wireless network again. I hope this helps!
Sep 21, 2011 | HP Compaq nc4400 Notebook
Internet connection okay with cable, no connection without cable.
Make sure that the wireless funciton is enabled I think its a button on the front edge you can't see its on unless you search for wireless networks, don't forget to use the WEP or WPA-PSK key to connect to your wireless router find you SSID and click connect
Jan 19, 2010 | Acer Aspire One PC Notebook
My wireless router wont connect to my laptop
Connect your Internet (DSL/Cable) modem to your router and power ON them both. Now turn ON your laptop's wifi receiver by either using a hard button, a sliding button or whatever button it is in your laptop's body. OR, maybe your laptop have a key combination to power on your wifi receiver like FN + F10. Make sure the wifi LED lights and there you can use your internet broadcasted by your router.
Nov 05, 2009 | NetGear WGR614 Wireless Router
Aspire 6930 wireless button not working
Without any wireless networks available, using your computer wirelessly is most pointless. If you want to set up a wireless access point in your home you need a wireless router, connected to Internet.
Sep 18, 2009 | Acer Aspire 6930-6771 Laptop
Hi my laptop (acer aspire 5672wlmi) wlan and bluetooth switch that are conntected to its motherboard have broken off and are broke is there any way that im able to turn the bluetooh and wireless on without...
I believe that you can turn these functions on and off via the Network Connections that you can access from the control panel.
In Windows XP:
Click on START button
Select Control Panel
Click on Network Connections
In Windows Vista:
Select Network and Internet
Select Network and Sharing Center
In left panel, select Manage Network Connections
Once here, you should see your wireless adapter and your bluetooth adapter. If you Right-Click on either connection, a menu will pop up and you can choose to Enable or Disable the connection without the button on the front of your computer.
Hope this helps.
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
I have just bought a laptop (acer5315)& its connecting to the internet(even though i dont have wireless internet access in my house)how is this happening please?i do have a cable connection through...
no you are probably unaware that you have connected to a neighbours connection who stupidly has not security encrypted the router.
It is illegal to use somebody elses connection without their permission, so i would suggest turning off the wireless adapter (slider button at front of notebook) until you get your own wireless connection.
Sep 04, 2008 | Acer Computers & Internet
My laptop won't connect to the internet through wireless connection
I have a compaq laptop. we have wireless and my other laptops work fine. this laptop just will not connect. it did before, but now it wont. help me.
Feb 14, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
265 people viewed this question
Ekse
Alun Cox
