I just bought a presario and did not give the allowed time 20 min to an 1hr for when you first plug up the computer for everything to load. What can i do to fix the problem i dont know much about computers and iam so upset with myself for not readin instruction in their entirety please help,before i cut off the machine it was doing what it was suppose to i just had no idea it would take that long to load.
    Problem Solver:
  • 28 Answers
Tell me the make and model... there is usualy a reset combination after normal start... It will reset to factory settings...
and TADA fix and let it run..and update when you get hooked to the net
You can look it up on the presario web site and it should give you that key combo (hold F7 after the beep or Delete when ou see th presario logo or something of that nature) and it will give you prompts....
If this is helpful please email and notify Fixya... Thanks
Posted on Mar 15, 2008
    Master:
    Sergeant:
  • 482 Answers
Run a restore disk if you have one.
SOURCE:
Length of time for just dough cycle do not want to bake in machine
Depends on the make of your machine. If it has a dough setting then just follow that. My bread machines have different times from 1hr 50 mins to 2hrs includes heat and another is 1hr and 20 mins
Oct 03, 2014 | Kitchen Appliances - Others
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
HP Compaq Presario F700, making loud noise and getting very hot, running super slow. If not plugged will only last 20 mins on battery only
system creating Noise/Heat MUST BE SHUT DOWN as Quickly as possible !!
you may hamper your computer.
Large Noise issues may be investigated only if you Open the computer Chassie.
It need Expert care and practice to open the systems.
You may give a try if you dont owe them or can take the risk.
after opening the chassie we can define the problem.. whether big or small.
Every problem has a solution !!
Rate this solution, Write a comment to keep in touch.
Sep 16, 2010 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario v2508 Multiple BSOD errors
so you need to reset cmos as memory modules must be out. is a virus instaled on mainboard so only way to recover control is these steps:
1st take the hd out.
2nd reset cmos
3rd take memory out
then put windows install cd and install as 1st time on computer, dont attemph to loading windows, or else you need to repeat-it again. then install laptop drivers, then test.
Jan 09, 2010 | HP Compaq Presario V2508WM (EP386UA) PC...
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Compaq presario c300 stuck in hibernation mode...won't recover or start up at all.
take out battery or unplug from wall open cpu or lap top and remove the inner memory batt. this will kill the last mode it remembers thats why its stuck. leave out for 2-4 hrs for best results. min 1hr and a half
Mar 14, 2009 | HP 435768-001 - Compaq Presario C300...
Screen turns black suddenly
Hi guys!
I think your problem is one of the following:
1- AC Device or Batteries.
2- RAM.
3- Graphic Card.
So, plz check them by order.
I hope this problem is solved.
Nov 04, 2008 | HP Compaq Presario V2000 Notebook
Presario s6500nx stops loading at set up screen
sounds like you have board problems.
unplug everything from it first and see if this helps could be something you have plugged up could be bad too.
you will have to open box and look for damage and then one by one unplug something and then reboot to see what it might be.
Aug 03, 2008 | Compaq Presario S6500NX (DQ181A#ABA) PC...
Boot up problem
I think you just got a corrupted bios.Its almost impossible to fix.Try pulling battery and power plug. Press power button for 20 secconds. put everything back and turn it on. If it dosen't work, try bringing it to the place where you bought it and try asking them for help
May 27, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Open Questions:
Computers & Internet Logo
24 people viewed this question
Ekse
Alun Cox
