Question about Kenwood KDC-MP528 CD Player
Hd ready? I was woundering if there was something you need to do to get hd radio. I have model ## kdc-mp528. i have read the booklet, and it says to use the src button to select the tuning source. But I can not get it to show up. Is there something that i need to bye to make it work?
  • 624 Answers
Yes , you need the HD tuner module that connects thru a din cord in the back of the radio. When a device says it is "HD ready" that means that it does not have it, but it can be connected and then used. Always look for that little tell-tale of being "ready". That is the give-away as to if it has it now, or it is only ready for it, meaning that it is compatible.
Posted on Jul 25, 2008
How do i install my alpine cd changer to a kenwood mp528 unit
It is unclear which Alpine CD changer you have and what output connections are available from it.
However your Kenwood unit has Aux input terminals at the back. With appropriate cable connectors you should be able to hook the two up. In the Kenwood you will have to select AUX in menu when playing CD changer. Download user manual for Kenwood from this site.
Search using full model number KDC-MP528
Sep 04, 2014 | Kenwood Car Audio & Video
Downloaded manual for Kenwood KDC-MP528, but instructions for setting clock time is sketchy, and can't get " clock adj." to come up, no matter in what sequence I hit instructed buttons....
Try putting the radio in standby mode and then hold the menu button in for a few seconds. Once you enter the menu, use the am or fm buttons to scroll through the menu. Then hold the seek up or seek down for a few seconds until the clock flashes, You should then be able to use the am/fm buttons and seek up and down buttons to set the hours and minutes. Once you have the time set, press the menu button again.
Aug 03, 2011 | Kenwood KDC-MP528 CD Player
Where to insert the aux input in the kenwood kdc-mp528
Its going to be in the rear of the radio RED/WHITE RCA should say aux input. you will need a RCA to 3.5mini cable
Feb 15, 2011 | Kenwood KDC-MP528 CD Player
My kenwood radio model number kdc mp 528 plays but dont nothin show on the display screen whats the problem
there are probably bad solder connections on some surface mount resistors inside of the deck.
Aug 25, 2010 | Kenwood KDC-MP528 CD Player
Need un lock code for a KDC-MP528 kenwood cd
Hey to reset the code on a Kenwood deck try this: Hit Disp 1 one second after V up spell KCar w/track up button it should work.
Sep 19, 2009 | Kenwood KDC-MP528 CD Player
KDC-Mp528 problem
The settings changed because when the battery died it was like resetting the unit. It seems that the problem is with the radio, not the car. Read over your owners manual to see if there are any setting you need to put back in. I can't remember off the top of my head what those settings would be. You can always push the reset button again and see if it clears up your problem, but you would also be clearing out all the previous settings. Sometimes you must have a device connected to the aux input for the radio to detect that there is something on it. Again, checking in your owners manual will tell you if there is anything you must do. Most problems of this nature will require a professional technician to figure out. I could do it myself if I had your radio on my test bench, but that is a little out of the question since I live in the US, and you are in Canada.
The reset button is the very small button that can only be pressed with the tip of an ink pen or something that small. It is on the display just right of the "6" preset button. If you have a security code on the radio, you will need it to turn the radio back on again. I can tell you how to clear the code if you need it, so don't reset the unit until I tell you how to clear the code. You don't want to go without any sounds at all.
If your car is not outputting the proper voltage from the alternator it could be causing the radio to not function properly, so check to make sure you have about 14 volts with the car running.
Most likely it is a problem with the radio, maybe the microprocessor.
Hope this helps,
Jul 04, 2008 | Kenwood KDC-MP528 CD Player
HI Ramo,
I appears to be impossible to put in a security code after the owner sets one. If you purchased this radio from someone and it is used, you need to get the code from the original owner.
Tha owners manual is at this URL
Good luck dude.
Nov 22, 2007 | Kenwood KDC-MP528 CD Player
Kendwood KDC-MP528
the easiest option is to replace the complete mechanism otherwise it involves stripping down the mechanism to determine if there are any parts of the mech snapped which can happen as it's mainly plastic
Oct 24, 2007 | Kenwood KDC-MP528 CD Player
Kenwood kdc-mp528 amp/speaker problem???
This is a common mistake. This problem indicates that you are using the solid blue wire from the head unit to the remote turn-on on the amp. This is a power antenna wire that only receives power when on FM radio. You need to replace this with the Blue & White wire from the head unit (power control wire) to your remote turn-on on your amp. This should solve your issue.
May 12, 2007 | Kenwood KDC-MP528 CD Player
Kenwood KDC-MP528 CD Player Logo
87 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
