Change TV to AV mode so as to receive signal from DVD recorder
My TEAC remote control (RC-773) is broken. I want to connect the television to a DVD recorder, but cannot change it to AV mode to receive signal from DVD recorder.
  • jayajaym Jun 27, 2008
    same problem
Facing simillar problem:(
Posted on Jun 14, 2008
My dvd remote does not work when i try to start movies
Greetings! Does your TV front panel works? If so, the problem lies surely on the remote control portion. But make sure first that the RC unit batteries are new ones. Turn on any portable FM radio receiver and point the RC unit near its antenna. Turning the dial knob very slowly, press any remote control keypads permanently. The moment you hear an oscillating sound from the receiver speaker, stop turning the dial and start to play with the RC unit keypads to find out if there is any sound changes, that means your remote control unit is emitting an infrared signal and its a healthy sign.! Then the defect is on your TV's remote receiver section, mechanically i. e. cold solder or electrically (defective components). Good luck!
Jul 04, 2011 | Televison & Video
Sponge bob DVD player will work on a regular TV but will not show up on the sponge bob tv anymore. Also tried a different DVD player and only get a blue screen. Shows AV then AV then tv or something. It is...
Hello
Your Emerson Sponge Bob's model will be SB350. It is a TV/DVD combo, with two AV inputs too. You ahve to see only DVD player with it as you says. You can change its mode to eiter TV/AV or DVD/TV by its remote control buttons. Press the DVD/TV mode button on the remote control to chage the modes to TV or DVD. On DVD mode, you can play DVDs with it. I thinks that you have its user manual with you now. Go to its pate [23] where there is illustrations for which button on the remote control handset should be pressed to select this. If you haven't its user manual with you, send your email address to me by FixYa comment box. I'll send a copy you the user manual to you by return mail. OK.
Jun 27, 2011 | Emerson SpongeBob SquarePants TV
Sony RDR-VX450 DVD/Video. I cany use the remote as when I press any button I get a message on the DVD "DVD2", this includes the menu button. How can I access the menu to reset to DVD3.
All you need to change remote control mode to DVD 2 so unit can receive DVD 2 remote signals.
Press and hold Enter and numeric 2 buttons on remote control for 3-4 seconds, this will change remote mode to DVD 2 in remote control, now dvd recorder will get DVD 2 signals and can be operated normally. No need to go back to DVD 3 mode.
Hope these info will help you.
Thanks.
Jan 19, 2011 | Sony Televison & Video
Display says it is stuck on dvd 2 cannot program the dvd recorder to record
DVD recorder stuck on DVD 2 mode that means you can no longer operate it with its remote, right?
Now you need to change remote mode to DVD 2 so recorder can receive its signals.
Slide down lower cover of remote and set Command Mode switch to DVD 2 position, now your recorder will get remote signals and you can operate it properly.
Thanks.
Jan 18, 2011 | Sony RDR-VX521 DVD Recorder/VCR
When i am recording from television and i turn television off the dvd appears to be recording but there is a blank screen when i check it to play
are you using AV jack to connect the recorder with TV for recording porpuse. if it's correct then it's simple, if recorder not gate inpute signal from TV, then it must show blank screen. coz it receiving the vedio signal from TV.
hope you get the answer.
thanks
Aug 01, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Connect AV receiver to a Dish receiver model VIP722 DVR
Your DVD player should connect to your TV, not the DISH DVR. Is the Yamaha some sort of receiver or something similar? If so, it should plug into the TV as well. The DVR just provides a signal to your TV, just like the other two components. On the back of your TV there should be other connections to plug into like HDMI1, HDMI2, AUX1, etc. You select which input you want to view using your TV remote. For example, if you were watching a DVD, you turn on the DVD player. Say it was plugged into AV1 or something similar on the back of the TV. With your TV remote, select which input you are using...that way your TV receives the signal from your DVD player and nothing else.
Nov 16, 2017 | Onkyo HTR500 Receiver
Remote Code
LG Television 553, 627, 653, 654, 693, 718, 766, 773, 804 LG Television 553, 627, 653, 654, 693, 718, 766, 773, 804 LG Television 553, 627, 653, 654, 693, 718, 766, 773, 804
  1. Program the remote to operate the device (for example, a TV), using the codes or Power Scan.
  2. Press and hold the mode button (for example, TV Mode for a TV), until all the mode buttons light up, then release.
  3. Press the PAGE UP on the remote control.
  4. Press # (pound) on the remote control.
To turn Limited Mode off, use the same procedure but press PAGE DOWN instead of PAGE UP on the remote. This procedure works for TV, VCR, and AUX modes.
also dish network remotes are not guaranteed to work w/ all tv's
Apr 03, 2009 | DISH Network ViP 211 DTV Receiver
Can't change TV to AV input.
dont bother trying to do it but then i got the same problem :)
Nov 30, 2008 | Televison & Video
No signal to the television set
Make sure that the DVD player's output is properly connected to the proper input on the TV, (Video1, etc.).
Oct 24, 2008 | Teac PLD2000 System
Toshiba CT-852
A universal remote would cure this problem. It's generally since they are on the same system or IR codes are similar. There isnt much you can do to fix that problem unless you have a seperate universal remote to opperate seperately.
May 05, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
944 people viewed this question
Top Televison & Video Experts
Electro Med Services...
