My Lacie wont mount its a rugged 250 gig, Was working fine till it got un plugged before being ejected. now will not mount. I can see it in disk Utilities. try to repair but can't the report is :The underlying task reported failure on exit, Verify and Repair disk ?LaCie? Checking HFS Plus volume. Checking Extents Overflow file. Checking Catalog file. Invalid node structure Volume check failed. Error: The underlying task reported failure on exit 1 HFS volume checked 1 volume could not be repaired because of an error
    Problem Solver:
  • 28 Answers
Mount.... sound like you got a Mac... Don't use the Mac sugested fix. The lacie Website has many revovery software options and Third party software is very good at that as well
I would try that first or try to contact a lacie tech and/or a mac tech.
If this is helpful please email and notify fixya. Thanks
Posted on Mar 15, 2008
The LaCie rugged 1TB keeps self ejecting...I have done disk repair and have reformatted. Is it a bad one?
1. yes and you will need to get a replacement.
2. there is a possible failing usb controller on the drive.
3. If you used the Window repair to fix this this has possibly made it worse.
Jun 14, 2011 | LaCie Rugged All-Terrain (301017) Hard...
Mac doesn't read the drive. Time Machine reads 'delayed' then 'failed' because it can't read drive. Won't backup. Drive doesn't show up on screen.
- Open the disk utility application found in the applications folder, then open the utilities folder
- See if it detects the LaCie drive by looking on the right hand side where it lists all the available drives including your optical drive
- If it is just greyed out you might only need to re-format the drive or possibly repair the disk.
- If it does not appear in this list the drive has most likely failed and is not economically repairable
May 17, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My Lacie Rugged 320 drive does not mount (is not recognized). The disk is rotating but no icon is found on the desktop. I have tried restarting, plugging into different ports and trying different machines....
Are you connecting it to the Windows now? If yes, Click on START > Run - type diskmgmt.msc
You will see your drive listed here
Right click and click on format (do not proceed if you need data on the drive)
Once done, you should be able to use it.
Oct 23, 2017 | LaCie Rugged Hard Disk hard drive - 301924...
My LaCie Rugged Hard Disk wont show up on my computer!!! need help asap or im getting firered!!
External hard disks can fail for a number of reasons, but check the device manager and disk management first to see if it is recognized (assuming you are using Windows).
Here are some more ideas: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Sep 07, 2010 | LaCie Rugged All-Terrain (301017) Hard...
Unable to access space on Lacie remote drive
The easiest way will be to format the disk drive. Highlight the icon, right click and format.
Feb 07, 2010 | LaCie (300770) 250 GB Hard Drive
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
Trouble seeing my lacie drive possible mounting issue
It sounds like the RAID controller in the LAcie drive may have failed. When this happens generally the data on the drive is left intact but you will require a new casing for the drives and the help of a data recovery pro to get the files off before you can re-initialize the set. Unfortunately all the good free/cheap utilities work only on single drives so you will need the help of a pro with high level software and additional equipment to retrieve the files.
If you are in North America I would recommend Armor-IT Data Recovery, they're listed in the FixYa service database for most US states. If you're outside North America, post your location and I will help you find an appropriate service.
Chris
May 28, 2009 | LaCie Big Disk Extreme with Triple...
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Help
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Dec 25, 2006 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
181 people viewed this question
Alun Cox
David Payne
David Payne
