Question about Akai LCT3201TD 32 in. LCD Television
Akai 27" wide screen LCD/HDTV/DVD Combo
I have an Akai 27" Wide-Screen LCD/TV/DVD Combo LCT2701AD and all of a sudden the sensor light in the remote does not connect with the sensor light in the TV. I have to manually turn on the Standby button on the TV and some times the sensors stays green and other times the senor response is very short and will turn red again and no TV. I changed the batteries in the remote, I changed plug-ins for the TV rechecked all connections were connected and still no communication with the remote. Does anyone know what I mean and what the problem means>? Thankyou
  • Anonymous Mar 29, 2008
    Thanks Hotsauce1 but it isn't just in the remote it doesn't connect even at the TV "on" switch. It doesn't hold the connection, occasionally if I had the patience to fiddle with it - it would come on after about 10 trys at the TV. However it never connects with the remote-fresh batteries etc. I will never buy anything again with the name Akai and I have also put the word out there. I feel burned.
  • Anonymous Dec 29, 2008
    same problem
  • 5 Answers
Some 1000uf electrolytic capacitors have failed on the power supply board (3x 16v & 2x 35v radial). You can get them at Radio Shack or your favorite parts house.
They are easy enough to replace if you are handy with a soldering iron. If not, bring the tv to a repair shop & tell them that you want the capacitors replaced on the power supply. It shouldn't be too expensive.
To get to the power supply, unplug the set from everything including power. Put the set face down on something soft that won't damage the screen. Remove all the screws from the rear cover, they have arrows pointing to them. When you get to the dvd player, care will be needed to get the cover off.
The power supply board is on the upper right side of the chassis and is not covered by anything. Look for the capacitors that are "bulging" on the top. These will need to be replaced. Good ones look flat on top.
Remove the bad capacitors noting there orientation (they are polarized). The "negitive" side will have a "band" printed on the capacitor. Go get the new ones & replace them carefully aligning the polarities correctly. Reassemble the case & you should be done.
Good luck. al
Posted on Feb 01, 2009
  • 62 Answers
The remote receiver is not picking up the remote transmitter. Call 800-726-4405
Posted on Mar 29, 2008
    Take the television into any service center - You will have to pay the bench fee - More than likely the parts will not be available to repair the television. Have the service center write a workorder stating that the tv cannot be repaired because the parts are not available. Then, Call Akai Customer service and request an exchange - 800-726-4405
SOURCE:
Need replacement remote control 5.1 Akai HHT-006
This company or eBay
AKAI TV Remote Controls ' AKAI Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/AKAI/Remote-Controls/
  1. Cached
ReplacementRemotes.com offers AKAI remote controls for sale online including remote controls for TV, DVD Player, TV/DVD Combo and many more. Missing: 5.1
Akai TV Remote Controls ' eBay
www.ebay.com > ... > Akai TV Remote Controls
  1. Cached
  2. Similar
AKAI KC02-A2 OEM Replacement TV Remote (LCT3701AD,LCT3201TD,LCT2701AD) ... Akai Samsung TV Remote Control Replacement BP59-00069A. $9.99. Missing: 5.1
replacement remote control 5 1 Akai HHT 006 Google Search
Apr 14, 2017 | Akai Televison & Video
AKAI LCD TV/DVD Player Combo connect to Motorola DVR Cable Terminal
Please follow guidelines given in operation manuals of both.
Aug 02, 2012 | Akai LCT2701AD Television
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide-screen lcd tv/dvd
Tramaine, I would suggest a new PSU. I have used ShopJimmy.com in the past with great success. Here is a link to the part you need on their site. Hope that helps! TeeVeeMan2
http://www.shopjimmy.com/megmeet-mlt168a-power-supply-unit.htm
Aug 18, 2011 | Akai LCT3201AD 32 in. LCD Television
TV screen won't come up
The power supply board or inverter. The power supply board is the first step. Look for any capacitors that are puffed up. Replacing them should take care of the PS. Check to see if you have 24 volts going to the inverter. If you do PS is OK and the inverter is most likely bad...good luck
May 08, 2009 | Akai LCT2715 27 in. LCD Television
HD ready?
It was not a problem. It is just a question. Is it HD ready or not without a converter box or cable?
I will go to a store and ask a tech if you can not answer.
thanks
Jan 14, 2009 | Akai LCT3201TD 32 in. LCD Television
AKAI 27" Wide-Screen LCD TV,
The tv is in protect mode, try first unplugging power cord for one hour, and see if this solve the problem.
Oct 08, 2008 | Televison & Video
Akai LCT2701AD - 27' LCD TV/DVD Player Combo
I don't know if I solved the problem. I find though if I turn the TV off and unplug it and then plug back in when I want to watch it - it works. I don't know why but it does. My remote still does not connect to the LCD but I have cable HDTV so chanel changes work from that control.
I am pretty ********** that it is only a year old and this has happened but what can you do? We live in a disposable world.
I was trying to get to your Premium assistance Plan from where I wrote my issue but I don't know where to pay or what to do on your site it keeps taking me all over.
Mar 15, 2008 | Akai LCT2715 27 in. LCD Television
Help me connect my components...
on the remote it should say menu it would probably be in the pitcher side set it to 4.3 or 4.5 or so on it is the setting you need ok hope that help
Jan 03, 2008 | Akai LCT2785TA 27 in. LCD Television
Akai LCT3201TD 32 in. LCD Television Logo
240 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
