Question about Lexmark X1240 All-In-One InkJet Printer
My x1240 scans but does not copy or print. What do you suggest?
My x1240 will scan but will not copy or print. The Lexmark Power Button blinks on/off continually. I have removed and reinstalled the power and USB connections and the software, each several times. Also restarted my Acer Aspire 5000 laptop.
  • jimb99 Mar 19, 2008
    the suggested solution was a very simple fix which worked immediately. Nowhere else had I been able to find a way to cure this problem. I am appreciative. jim b.
    Genius:
  • 2,035 Answers
You will need to do the following diagnostic tests to determine the exact cause of the error:
· Remove the ink cartridges
· Perform the self test (test B below)
· Test the ink cartridges
A. To remove the ink cartridges:
Switch the printer on by pressing the green button.
Open the front cover of the printer. The cartridge carrier should move to the center of the opening.
Remove both cartridges.
If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand.
Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer.
Inside the printer, locate the silver metal carrier bar on which the print carriage slides.
Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion.
Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening.
Now pull both cartridges out.
B. To perform the self-test:
Disconnect both the power cable and the USB or parallel cable.
After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.)
Turn the printer off by pressing the green power button.
Hold down the grey paper feed button.
Turn the printer on by pressing the green button.
After the printer begins to feed paper, release the grey button.
Once the paper exits the printer, press the green button to turn the printer off.
If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. Please contact our Technical Support Centre for your service options. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below.
C. To test the ink cartridges:
Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place.
Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step.
Turn the printer off using the green power button.
Hold down the grey paper-feed button.
Turn the printer on using the green button.
If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly.
Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly.
If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase, or contact our Technical Support Centre.
IF u have problems u can use this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Posted on Mar 16, 2008
How do I make a copy on a lexmark x1240 printer without a computer?
hi
you cannot do that with this printer ,as the computer needs an output program to work from. hence the CD you may have is the drivers and applications to be installed onto a computer to get the print result or scanned result.
you need a computer to drive the printer .
hope this helps
Jan 28, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have downloaded my printer x1240, but I cannot scan nor copy it is not been downloaded how do I get that back up?
The scan software can only be installed using the installation cd that came with your printer. The scan software is not available for download since it's a big file. If you don't have the cd, better call Lexmark at 1-800- LEXMARK(1-800-539-6275). They can better assist you with that. They might send you the cd. Good luck!
Apr 01, 2010 | Lexmark X1240 All-In-One InkJet Printer
Have a lexmark x1240, I don't have a manual. It will print from the pc but I don't know how to make it scan or copy.
go to lexmark.com support drivers and manuals enter model number, you can get an online or printable manual there..
Nov 28, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark x1240 All-In-One Printer Control Panel
Hi
This is the description of printer control panel
green button-START COLoUR COPY BUTTON.....place a documnet on scanner glass...press this button..u would get colur copies of the document
Black button-START BLACK COPY BUTTON.....place a documnet on scanner glass...press this button..u would get black copies of the document
white button on the left hand side-paper feed button..to load paper into the paper feed tray
white button the right...not sure:)....i guess it should be the scan button....
all the best
Apr 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
Scanner not workin-lexmark x1240
Which operating are you using if your using (Vista use windows photo gallery to scan)
Mar 28, 2008 | Lexmark X1240 All-In-One InkJet Printer
Printer
It will not print when power button blinks, you must clear jam or reset until power button is on steady.
Feb 11, 2008 | Lexmark X1270 All-In-One InkJet Printer
All in one printer does not scan or copy
If the Ink Status is showing a ? symbol after you have replaced the tanks, you just need to tell the printer that you replaced tanks ,
To do that , open your lexmark solution centre from the Lexmark start menu group.
Click Maintenence
Click Install New Print Cartridge
Jan 18, 2008 | Lexmark X1240 All-In-One InkJet Printer
Will not copy or scan
go to www.lexmark.com and click on Support: http://support.lexmark.com/cgi-perl/support.cgi?lxkprod=Lexmark+X1270 Under Support Tools you should see e-mail Support. Fill out the form and provide as much detail about your problem. If you have have Win Vista as your OS then call 1-800 Lexmark. If you have problems understanding the agent then I highly suggest the email or chat support. Yeah Lexmark has chat support also and they monitor all support and want to know about their agents good and bad. Can't fix what they do not know is broken and that goes for training also.
Sep 26, 2007 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1185 won't scan.
I believe you have to push the scan button in order for it to scan and save. The copy buttons will only print either a black copy or a color copy.
Sep 12, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1240 All-In-One InkJet Printer Logo
150 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
