Question about Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator
Kenmore coldspot refrigerator
Ice maker get water for one round of icemaking then no water. I have checked the supply line and the water flows freely. I took the pump assembly out to check the filter screen. it was clogged. i took it out an soaked it in white vinegar which loosened 95% of the debri. I checked the pump action for additional particles and flushed out with clean water then reassembled. Now the pump comes on but no water comes into the tray basin. Is the pumps bad or is the tiny bushing inthe screen filter area chocked thus not allowing enough flow?
Thanks,
Thom
  • tl2sea Mar 17, 2008
    From the solution posted by "aborcass" , I checked the tubing leading to the Ice maker by using a "Turkey Food Baster" to pressure pump water into the maker's tray---worked fine. Aborcass mentioned the "pump action", basically the electro magnetic solenoid part of the pump. Well I did not rig any pseudo electric switch to test the pump instead my neighbor had just replaced his dishwasher of which the old one had a solenoid pump similar to the Kenmore Ice Maker unit, so I took that part and removed the electro magnet plus the plunger and spring. Then it was a simple matter of making sure the water connection was turned off, power was disconnected then remove the plate holding the electro magnetic solenoid onto the pump, pulling the plunger assembly out (carefully so as not to lose any pieces) then dropping out the old plunger and spring. Once this was done then simply insert the new spring and plunger, replace the plunger assembly into the water pump well then reattach the metal plate with the new electro magnet in place. Be sure the mount "notch" in placed such that the electrical connection fit back on easily and that the cross over ground wire is connected across from the plunger pump to the screen filter. Once all is snuggly tight reconnect any water lines - if disconnected - and the power plug then fasten back onto the back of the refrigerator, plug in the main power, maker sure the ice maker activaion lever in set to make ice then in about 30 minutes you should see your first batch of ice. By the way when reconnecting the water line to the ice maker tray I used the "Turkey Baster" to fill that line prior to reconnection to eliminate air and delays. Sure there was a slight amount of water in the tray but everything worked and now I have plenty of Ice. Total cost 1 1/2 hours of time and Zero parts cost just creative thinking.
    Thanks for the guidance Aborcass.
    aborcass
    Rank: Guru
    Rating: 86%, 361 votes
    checked the pump action????its a water valve powered by 110v.se if you can rig a test cord and plug into the valve itself see if you get water then. also check to tubing leading to the ice maker for possibly being frozen, as a result of poor water flow in the first place
    President:
  • Kenmore Master
  • 2,651 Answers
Checked the pump action????its a water valve powered by 110v.se if you can rig a test cord and plug into the valve itself see if you get water then. also check to tubing leading to the ice maker for possibly being frozen, as a result of poor water flow in the first place
Posted on Mar 15, 2008
SOURCE:
Ice maker in kenmore coldspot refrigerator quit making ice, nowater flow
There are several causes of no ice maker operation. First, is the freezer cold enough? It must be below 32F to operate the icemaker. 2nd: Is the bale or metal rod that runs along the side of the ice maker in the down position? 3rd: You may have a failed water solenoid valve, located on the back of the unit. The plastic or copper water line from your house's water supply is attached to this valve.
Apr 11, 2015 | Kenmore Refrigerators
Does the ice maker filter have to be in for the fridge to work right it is a Kenmore Coldspot
? I don't believe there is a "Ice maker" filter just for the Ice. There is a water filter for both the icemaker and cold water (usually). Check your Owner's manual. Usually there is an option for water filter or no water filter. The no water filter option requires a "bypass" device to substitute for the filter, but of course the water is not filtered, unless you have an external water filter in the supply line to the refigirator. Hope this helps. Of course if you have no water supply, the Ice Maker will not make ice.
Mar 03, 2015 | Kenmore Refrigerators
Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
Mar 01, 2015 | Kenmore Refrigerators
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2010 | Refrigerators
Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Oct 30, 2009 | Refrigerators
HOOK UP OF ICE MAKER TO THE WATER LINE
What you have in the back is a 1/4 tube which will feed cold water to the icemaker.
go to any hardware store and ask for an icemaker supply line kit. It will consist of a tapping valve, about ten feet of 1/4 inch tubing and a straight connector.
it will also contain step by step instructions.
You will have to determine what cold water line to tap into that is accessable. Perhaps the kitchen sink cold water supply if it is on the same wall as the refrigerator. Many times the line is run up from the basement.
enjoy your new icemaker.
May 21, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker isn't filling with water. Water is on and ice maker is on. It's been humid.
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore ice maker
yes you need to hook up a line froun the cold water supply of the house to the water valve that is located at the back of the ref to the water valve that is down at the botton right corner
follow the water line from the top going into the icemaker down to the bottom there is where the valve is located behind the back cover
Apr 11, 2008 | Refrigerators
Kenmore 62232 / 62234 / 62239 Bottom Freezer Refrigerator Logo
817 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
