Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
CL in display
I cannot get this door switch to acknowledge that I have closed it. Is there a way to repair/test it?
  • 2 more comments
  • Michael9040 Mar 15, 2008
    Yes, definitely.
    Thanks for responding!
  • Michael9040 Mar 20, 2008
    The ribbon trick didn't help. I took the latch assembly off trying to figure out how to bypass it. When I reinstalled it the machine worked for a couple of days but now has the same original problem.
  • mrdelker1 May 31, 2008
    CL blinking. I cannot get dishwasher to start.
  • robert samples May 11, 2010
    does the door latch when you close it
    President:
  • 1,314 Answers
Take the screws out from around the top and take the control panel off to access the door latch assembly but first take the mylar ribbon off from the control panel and clean it with a pencil eraser gently and replace the ribbon see if that clears it and let me know now leave the two lower screws in the door panel so it wont come off
Posted on Mar 15, 2008
My dishwasher FDB2510LCC1 get a cl code while washing and stays running on the wash stage until it is shut off
Hello Randy, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher is displaying an error code of "CL" this means close door. The dishwasher may not be sensing that the door switch is closed. The "CL" means that you could have a possible issue with the main control board or door latch. I would recommend checking to make sure the latch does not have any visible damage. This could also be a miscommunication within your dishwasher and a reset may help clear it out. In order to reset the dishwasher you would flip the household circuit breaker off for at least ten minutes. We hope this information is helpful to you. -Matt
Jan 28, 2016 | Frigidaire Dishwashers
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
I have a Frigidaire dishwasher model # FDB2415LFSO with a blinking CL code. When I try the normal wash cycle button the drain pump runs and the CL light blinks continuously and nothing more happens. The...
Good Afternoon friend, thank you for your post!
Based off what you have described you have performed multiple tests to your Frigidaire dishwasher and it continues to display a "CL". That code does stand for close door which can mean that the door switch is sensing it is opened. For this error code it could be a possible problem with your door switch or main control. I understand you stated that the control did not appear to have a burn inside of it so it is easy to assume that the door latch could be the issue. Remember if you are not a professional technician this could be the start of unnecessary part purchases. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
Why won't my dishwasher start?
Thank you for your inquiry, friend!
Based off the information you have provided "CL" stands for close door. If you continue to experience an issue with the "CL" error code I would recommend having a professional come out to your home and diagnose your appliance. "CL" could be a problem within your door switch or main control board. Hopefully this is helpful. -Matt
Aug 28, 2014 | Electrolux Dishwashers
Washing machine Siemens iq300 has error CL in display (status) & can't be used
This means that the door is not being closed. It might be a bad door switch.
Mar 27, 2013 | Washing Machines
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Daniel
Nov 26, 2010 | Frigidaire PLD2855RFC Dishwasher
Flashes "CL" to close door when it is closed and won't start
The door switch has failed. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing. It may be a different model but the process will be the same. You can also enter your model # for diagrams and illustrations of your specific model.
May 21, 2010 | Frigidaire Dishwashers
CL Error Dacor Dishwashwer
I had this problem and it was driving me crazy! I finally figured out what it was, in my case. I thought that the door switch would be the problem, so I took the door cover off and jumpered out the switch. No luck. While I had it apart, I noticed that each time I bumped the main control board, I heard a short, and heard a relay close. I found that the main control board wasn't snapped all the way into its mount on the left side. Apparently, there is a contact on the back side of the board that only makes when the board is fully seated. Snapping the board firmly into place has fixed my problem.
Mar 30, 2008 | Dacor Dishwashers
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
124 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
