Question about Motorola Mobility SLVR L7 Cellular Phone
No sound whatsoever
I originally has issues with the earpiece not being loud enough. I downloaded P2KTools and adjusted. Made no difference until today when I restarted the phone so it would recognize my microSD card. Then it was WAY loud. I went back to P2KTools to adjust, and now I have nothing. No sound, no ring, no beeps on the keypad, no speakerphone, no sound thru headphones, nothing. I did a master reset on the phone, and still nothing. My card works, and I can use iTunes, but not a peep from the phone. Any help?
    Brigadier General:
  • 7,752 Answers
Well this is why most things are done by the prfessionals you need now to take your phone to a mobile tech or mobile service center and have them correct this software issue on the main-board.....but if you use p2ktools did you not back p your firmware before adjusting the phone....if yes then just reload the backup firmwarew on to the phone and this should correct the issue with the sound.
Posted on Mar 29, 2008
Having trouble with right earpiece not as loud as left on my lg hbs750
Probe the Settings for how to pan the sound. If you do, put the slider to where you like it and that's it! If you don't find it, try going to a local mall to a BOSE store and see if the problem occurs with their demo products. More questions? Just post a comment! -Mr. W
Aug 23, 2014 | Cell Phones
My volume gets loud for music but soft for dialogue depending on the channel and part of the show/movie
Most of this is how the original material was mixed during production. Commercials are generally broadcast louder than the programming too. Try changing the sound field in the TV menu. Under the "Sound" menu of most TVs there are preset fields that are kind of like EQs. If you have a DVR, try different ones listening to the same show you are having issues with. The adjustments in most TVs are very limited. An external audio source (receiver, HTIB, soundbar) would give you more adjustable.
Apr 16, 2011 | Televison & Video
N73 low sound for top loud speaker and earpiece when calling
HI, when a cell phone has Low sound for top loud speaker and earpiece when calling , it is when the loud speaker and the earpiece are weak to perform accurately and will need to be replace for better sound quality for your cell phone.
When a phone drops on the flow or water gets into it,might cause the hearing of the lod speaker sound to go weaker and weaker every time.
When you replace the ear piece and the speaker, you phone will work perfectly again.
If when you replace the speaker and soundisstillthe same , that means it's an IC chip problem inside the cell phone . An expert will help you on that.
Hope it helped.
Thanks for using fixya.
Feb 10, 2011 | Cell Phones
Have a sony ericsson C905, the earpiece is not working, the phone works fine on loudspeaker.
dear friend,
the earpiece may be damaged so get it replaced...the loud speaker piece & earpiece are different
hope this will do...
enjoy & cheers
Jan 17, 2011 | Sony Ericsson Cyber-shot C905 Cell Phone
No sound whatsoever on LG KG800 Chocolate Phone
easiest way to solve this problem. go to call settings and TTY mode. and switch it to TTY + talk ... if that doesnt work then fiddle around with the other TTY settings untill it does. this disables the earpiece
Dec 09, 2008 | LG KG800 Cellular Phone
How to import pictures from Motorola V3 phone to PC,
You will need the P2KTools and the USB Drivers. Try downloading them from here. http://p2ktools.en.softonic.com/java
If this does not work i can mail you the set that I use on a regular basis.
Hope this fixes your issue. Please mark as solved if it does.
Nov 28, 2008 | Motorola Mobility RAZR V3
New Phone Causing Echo
It sounds like your microphone volume is too loud. Get someone on a call with you so they can tell you how it sounds as you adjust it. Turn down the mic volume by pressing the + & - buttons on the earpiece together once which puts the earpiece into mic adjust mode. Then decrease the mic volume by pressing the minus button a few times until it sounds right. The earpiece will automatically revert to normal mode within a few seconds.
If this doesn't work it may be that you need to adjust the compatibility setting for the new phone. This is the small black dial on the base station. The most common setting is 'A' but you may need to experiment with other settings for that phone.
Nov 04, 2008 | GN Netcom GN 9120 Professional Headset
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Can't hear
Ok so you turned the volume right up and it didnt make a difference ?
well i'd suggest you take in into a cellular dealer, and have them look ate the speaker or the amplifer on the main board.. I could just be your speaker is shorting and needs to be replaced. If it works good on loud speaker, its deffenately the speaker or the amp..
Jan 24, 2008 | Samsung SGH-T719 Cellular Phone
i got the same problem...what a POS phone, also sucks for text messaging. if you switch to speaker phone u can have your convo, but i have a loud car and cant hear speaker, need the earpiece, but its totally dead :(
Nov 21, 2007 | LG KG800 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
