Question about Kitchen Ranges
Smeg Oven electric burning smell
Smeg SA420X Oven
When I switch the oven off after using it there is a very bad electric burning smell coming from the back of the oven so much so I turn the power off form the switchboard. This only happen after we have used the oven and switch the oven off at the controllers
  • Anonymous Sep 22, 2008
    I have exectly the same problem, did anyone find out what was broken?
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Posted on Apr 01, 2008
EW30EW65SS Stainless Steel smells like burning electrical
Hello purrpplee - If the smell is coming out of the oven vent, more than likely it is something inside the oven that is creating the odor. Also, keep in mind that new cooking products can create a burning electrical odor when the bake and broil cycles are used as any residual coating or film on the oven liner and elements burns off. However, if odor increases consult a professional for an accurate diagnosis.
Jan 31, 2013 | Electrolux EW30EW65SS Stainless Steel...
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
My smeg willl only work on the grill setting,. when I use the oven switch everything comes on but it does not heat up
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 13, 2011 | Smeg SE280X Stainless Steel Electric...
Smoke coming from electric oven element
if it is the upper element is smoking when in use then its usuall grease/fatty deposits that have attached itself from previous cooks.. the only way to rid is to open doors & windows then turn to max temp to burn off... 5-10 mins usually suffice dependant on quantity. looks bad initially but soon it will be heating clean again..
Dec 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Electrical fault on SE250Xuk
It may be something as simple as a crossed or frayed wire. This does not necessarily mean major repairs. Since it is electric, UNPLUG the oven from the wall. Then, take the burner rings out and lift the stove top. You should be able to lift it from the front edge, since it is hinged at the back.
Check the wires under the burner. If these wires are in good shape and the connections are solid, move the stove out from the wall. Remove the back sheet metal panel completely.
Once again, check the wires running the entire length. Make sure all wires running from the knob console to the rest of the oven are not frayed or missing the insulation coating and that the connections are complete and not loose.
If you find frays, some electrical tape should fix it just fine. Loose connections can usually be crimped with a pliers, or if it's a loose electrical connector type connection with a screw, you can remove the connector head and wrap bare wire around the screw, then tighten it down to secure.
If you find nothing wrong when you open it and inspect the wires, then it is possible it needs major repairs. If you are getting a burning smell from ANY electrical appliance, please leave it unplugged until you get it fixed. Nobody likes a house fire in the middle of the night.
Mar 03, 2009 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smoking Fan Assisted Oven
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
Jan 20, 2009 | Smeg SE399X/5 Stainless Steel Electric...
SMEG SA420X
Not too common at all.Tough call ,you really can't hold the tenant at fault,replace the over priced clock and inform the tenant that the next one THEY will have to pay for.
Jun 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
1,386 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
