Question about Kenmore 15358
My sewing machine makes globs of thread on the underside of the fabric
The bobbin thread globs up imediately on the under side of the fabric . the first line I sewed was fine then it went crazy. I don't have a clue where to begin looking for a solution. I've waited 40 years to buy a sewing machine because I knew this would happen. It's really kind of funny! i thought the thickness of the fabric was the problem, but I tried a thinner piece...still did it. I loosened the tention slightly...no help.Now I'm just going to eat something. that usually helps most problems. ha ha.
  • janbills Mar 15, 2008
    Same problem here with my Singer 2950. I am getting restless! Have tried everything, to no avail! Help!
You might also try holding both the top and the bobbin thread with a little tension when you first sewing.
Posted on Aug 09, 2008
This happens to me when the machine is not threaded correctly, make sureyour machine is threaded right, then adjust tension if it still happens.
Posted on Apr 11, 2008
Model number 4562. The bobbin thread bunches up. How do i fix?
Check your stitch sample. Is it the bobbin thread that is making a thread mess, or is it the top thread throwing thread globs under the fabric? Usually, if there is a thread problem under the fabric, it is a top thread issue.
Try this:
Remove the top thread completely from the machine.
Install a brand new needle
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Retest your machine and tweak the tension, as needed. If top thread is showing under the fabric, tighten the top tension. If the bobbin thread is showing on the top of the fabric, loosen the top tension. Tension is correct when the two threads meet in the middle of the fabric.
Feb 26, 2018 | Sewing Machines
The stitches on the underside are looping I’ve retreaded both the needle and bobbin and neither makes a difference
You are getting a thread mess under the fabric? Frequently, this occurs because the top thread is not fully seated in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the machine from the beginning.
If necessary, adjust the top tension so the top and bobbin threads meet in the middle of the fabric.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
TIP Avoid Thread Bird Nesting with these Four Tips Stitching Sewcial
Troubleshooting Thread Nesting Sew Toot
Jan 04, 2018 | Sewing Machines
Bobbin issues the bobbin thread is bunching up
Check whether it is bobbin thread or the top thread accumulating under the fabric. Generally, if thread problems exist "under" the fabric, it is a top thread issue. If the problems exist "above" the fabric, it is a bobbin issue.
Sounds like a thread nesting (bird nesting) problem where the top thread is globbing under the fabric. Usually, this is caused by misthreading (confirm the thread path), the thread not seated in the tension disk (ALWAYS RAISE the presser foot when threading!), or very loose top thread tension.
Remove the thread. Raise the presser foot and rethread from the beginning. Check that the thread path is correct. Set the upper tension at the midway point between high & low numbers (this is the beginning point for tension and will most likely need to be tweaked for your particular machine).
What causes Bird Nests Superior Threads
Dec 11, 2016 | Sewing Machines
I HAVE MODEL 12312 AND CANT GET THE BOBBIN TO WORK, THE BOBBIN KEEPS GATHEREING UNDERNEATH MY WORK. ANY SUGGESTTIONS
Please check your fabric results. Is it the bobbin thread that is accumulating under the fabric, or is it really the top thread that is globbing and knotting under the fabric. Usually, thread mishaps under the fabric are the result of an issue with the top thread.
ALWAYS RAISE the presser foot when threading the upper thread. This releases the tension disks so the thread will seat properly. Use a brand new needle. Start out with the upper thread tension set midway between high & low numbers, although this can be tweaked.
If it is in fact the upper thread, then here are some suggestions:
Nov 29, 2016 | Sewing Machines
Lower thread wads up and the machine doesn't want to go in reverse
Check the bobbin case.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
My bobbin thread continues to bunch up on the back of the fabric.. How can I fix this?
3 Common Sewing Machine Problems and How to Fix Them
Dec 29, 2015 | Sewing Machines
Kenmore 15358 Logo
217 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
