Question about Frigidaire GLD2445RF Built-in Dishwasher
Broken nozzle and upper spray arm
The upper spray arm/nozzle fell off when I loaded too many dishes in the top rack and tried to pull the rack out. Nothing appears to be broken but there seems to be no visible way to reattach the upper spray arm. Thanks!
  • 3 more comments
  • dmaust Mar 31, 2008
    Happened to us, just the arm popped off. Looks like there is a little piece in in there but nothing to screw. Does the larger piece that the arm attaches to unscrew?
  • dah31 May 31, 2008
    The big starry guy on the ceiling (of our GLD2440REB1) unscrews, and there's a little plastic piece in there that you can use to attach the starry guy to the arm.  Ours then falls off in the next wash.  I'm going to try and jury-rig something up to hold it together before I resort to buying a new part (US$7.65 plus shipping).
  • kmgreen Apr 25, 2009
    The upper spray arm on mine bopped off, too. But I can't see anything at all to fix it to. Do you have the take the whole thing out of the counter to get at the top? AAARRGGGHHH! My dishes are not getting clean!
  • Vicky Heeger
    Vicky Heeger May 20, 2014
    What is the part number you are referring to?
Thanks for the help. Like the other guy said the "ninga star" thing unscrews and using the plastic part inside I just pop the spray arm back on. Screw it back and it works again.
Posted on Aug 29, 2009
    Problem Solver:
  • 12 Answers
Ours had a sort of plastic "ninja star" thing (Google images will show you what I mean) screwed to the inside ceiling, with a sort of washer-like piece behind it.  When I got the replacement part from Sears Parts Direct, the several plastic parts clipped together.  Then I screwed the ninja star back on (the upper spray arm swivels freely).  Nearly a year later and it's still holding together.
P. S.: Check for coupon codes before you buy a part: RetailMeNot shows coupon code 80081 for $10 off from Sears Parts Direct!  I believe I used that one for a carpet cleaner hose a couple of months ago, but I had to add some other stuff (I used lawnmower parts) to bring it up to $10 before shipping in order to use the coupon code.
Posted on May 19, 2009
    President:
  • Frigidaire Master
  • 2,651 Answers
The spray arm just screws back on, unless of course its cracked in which case needs replacing( chances are since it fell off its cracked) heres the part num 154478202
Posted on Mar 15, 2008
My Hotpoint dishwasher works fine except that it will no longer wash the dishes in the top rack. It's like the water is not coming up far enough from the bottom to do the job.
There should be an upper spray arm to wash the upper rack, it may be stuck. Look at its position, run the machine a few seconds and see if it moved. The spray nozzles on the arm often get clogged with food particles. the pipe feeding the spray arm has to extend when you pull the rack out and retracts when you push it in. Make sure it works properly and has not disconnected.
Sep 04, 2017 | Hotpoint Dishwashers
The spay tower in the bottom fell out. should
If the spray tower is not in place then water will not get to the spray arm for the upper rack. You should be able to re-install the tower. Look for small tabs at the bottom that fit into slots in the mounting. The tabs should snap in or lock when the tower is turned slightly. If the tabs are broken off you should replace the tower. You can use the dishwasher without it but he dishes on the top rack will not get cleaned and the pressure tot he bottom spray arm may be reduced causing dishes to not get completely coean.
Dec 21, 2009 | Kenmore Dishwashers
Top rack does not wash dishes.
Possible causes of spray arm inefficiency:
Loading large or tall items in the lower basket which stops the arm revolving.
Upper spray arm split along seam.
Upper spray arm blocked.
Under dosing of powder causing foam and reducing upper spray arm water pressure.
Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure.
inefficient wash motor impellor (faulty)
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Hi, the dishwashers top rack dishes are not being cleaned.. help?
sounds like the upper spinning arm is not turning check to see if it is clogged at the nozzles if so take off and clean particles out also check bottom ofjet that spray soap up to upper spinner and see that is not blocked
Nov 12, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Feb 14, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Kenmore 665.16389300
Test by pulling out the lower rack and run an upper load, it may just be a loading issue. Some washers are better than others, in that they have stronger moters and impelors than others. The impellor may have something like a fork, knife, or broken glass in it.
Jun 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Frigidaire GLD2445RF Built-in Dishwasher Logo
2,030 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
