Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Part for entire hose including the connection to the water out take.
The hose broke at the base of the out take water. Is there a part to replace the whole attachment that hooks to the base. I lost my manual.
    President:
  • 1,673 Answers
Looks like you have to replace the complete hose asm. part #90001336.
Posted on Mar 15, 2008
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
How do I replace the part where the hose snaps into? It's directly behind the switch plate.
Hi Eric,
Thank you for your inquiry. If you are referring to the flexible hose and where it connects to the machine (which is at the base), the entire duct assembly would require replacement. However, if you are referring to the wand handle, and where it connects to the machine behind the power button (or where the hose connects to the wand handle), part replacement is possible.
We would appreciate the opportunity to help you determine which part is necessary to resolve this problem. Please call us directly at 1-866-693-9766 (US) or 0800 298 0298 (UK) so we can provide further assistance.
Best wishes,
Jessica
Jun 26, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover rug scruber hose broke from clean water to brushes it has an inter hose running through it
Is this the 1 1/2" clear hose that is on the right side that you can see when the handle is released? It stretches for the base of the machine to the upper handle? If it is, the hose must be replaced. The ends on the hose are permanently attached during manufacturing.
Nov 16, 2011 | Vacuums
My Epic 6500 power head will not turn on. Had to push the reset many times the last time it ran, and now it will not turn on. Help!
Does the power nozzle motor come on? Is it just that the brush won't turn? If it's just the brush not rotating, the belt probably broke and needs replaced.
Is the brush clean? If not, clean all threads, etc. off.
Check all wire connections for breaks, cracks, and discoloration. Power nozzle to wand, wand to wand, wand to hose. If any of those are found, that part, and probably the one it connects to. will need replaced.
Ensure all connections are snug.
Internal wiring, including connections, could be bad. This would include wiring in the power nozzle, wands, hose, or canister.
Reset or hose switch could be bad. These would need replaced.
Power nozzle motor could be bad. Generally the belt will break before the motor burns out, but it's possible it's didn't.
For any internal repairs, including belt replacement, the entire vacuum should be taken to an authorized Aerus Electrolux dealer. The service technician can also troubleshoot and find the problem. This is generally done at no charge.
You've got a great machine, and with proper care and maintenance it should last for years to come.
Dec 22, 2010 | Electrolux Epic 6500 Vacuum
Hoover steam vac hose broken so I get no suction.
The entire hose has to be replaced. I beliive they run about 39.99
Jun 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover steam vac max - hose that sucks water up from carpet broke
This is common, the vinyl gets brittle and cracks, you can get it repaired but not for free.
Mar 26, 2017 | Hoover Vacuums
The clip that connects the water base to the top of the suction area broke off..where can I get a replacement base (the part where you put the water in and has the bag where you also store the dirty...
Here is the number for Bissell, they can tell you who to contact near you.
Service Center Dept. Phone Number:
(800) 457-1509
Service Center Dept. Fax Number:
(800) 517-9535
Hours:
M-F 8:00 a.m. - 5:00 p.m. ET
Aug 10, 2008 | Bissell Vacuums
Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Electrolux EL7055 just stopped
They aren't quality machines, they are made by Eureeka, not Electrolux. Aerus/ Electrolux is really the way to go!
Sep 27, 2007 | Electrolux EL7055A Bagless Canister Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
57 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
