Question about SanDisk Sansa m240 MP3 Player
Starting problem with new sandisk m240 1gb the power on button is not working ..i have just bought it new put a new battery and started..plz help
  • Benjamin Patri
    Benjamin Patri May 11, 2010
    You are holding down the power button for an extended period of time correct? 5 secs or so should be good
  • 3,037 Answers
If the power button plan doesn't work, let me know
Posted on Mar 21, 2008
How to turn on my Toshiba satellite L305D-S5974, YESTERDAY IT WENT DEAD AND NOW I GOT THE CHARGER BUT ALL I SEE IS AN ORANGE LIGHT BLINKING BUT IT STILL STAY OFF NO FAN,NO SCREEN AT ALL, HELP PLZ
Remove the power cord and remove the battery. Press and hold the power button for 30 seconds... no less... Put the battery back in and plug in the power cord. Try to start it.
If it doesn't work, try again without the battery, just the power cord.
If that doesn't work neither, remove the power cord, and leave it without the battery or power for a couple hours. 3 minimum.
Put everything back and try to start it up again.
Good luck.
Apr 25, 2016 | Toshiba Computers & Internet
My sansa mp3 just froze in the welcome screen when you turn it on
You can try to reset the device by pressing the power button for about15 to 20 seconds..if that doesnt work I would recommend you to go tothe sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jan 22, 2009 | SanDisk Sansa Connect MP3 Player
I have a sansa sandisk mp3 player. when i bought it it was working excellent.but all of a sudden it stopped working.this mp3 has no reset button i do not know how to fix the problem. sansa sandisk...
1. Are you able to turn it on ?
If so, press the the "power on" button the second time to activate the menu.
Still no luck ! Try putting in a new battery and try again.
2. You cannot "reset" anything.
3. Open up "windows explorer"
4. Scroll down the left pane of the window till you see the "sansa" removable disk
5. Right click it and select "format"
6. After formatting, try adding your files back again.
7. Use the >= button on the player tp play the songs.
Hope this has been helpful to you.
Aug 29, 2008 | SanDisk Sansa m240 MP3 Player
Frozen sansa e-250
Hold down the power button for fifteen seconds. Sometimes all the unit needs is a good soft reset.
If, for whatever reason, the unit is still unresponsive, you will need to force-format and downgrade the player. Instructions on how to do this can be found here:
http://www.anythingbutipod.com/forum/showthread.php?t=11233
May 22, 2008 | SanDisk Sansa e250 MP3 Player
How Long to Charge??
sandisk recommends 3+ hours for the initial charge and then about 1.5 - 2 hours for after the battery is drained. More information is needed to diagnose this problem. but here is some info. After 45 minutes on the phone with sandisk to get them to send a new battery, they ran me through these troubleshooting steps, hope they help. do one at a time and see if you get a result -Reset device take out battery hold power button for 30 count put battery back in turn device on. -Upgrade firmware Go to website, download firmware update This was the URL at the time of writing this http://sandisk.com/Retail/Default.aspx?CatID=1376 or try http://sandisk.com/Retail/DriverDownloads.aspx Install according to instructions. let the device reboot. -Format memory. turn hold switch on, orange should be visible hold pause/play button and press power. click forward button when the screen comes up. let this run. after reboot flip the hold switch off. then they put me on hold for 10 minutes...
Aug 19, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa SanDisk c150 won't turn on!
My Sansa also failed to turn on. But what happened to me was that I unplugged the USB while it's connecting. After that I cannot sync with my computer anymore, so I tried turning it off and on couple times and at the end the whole thing won't turn on anymore. I talked to the SanDisk tech. You can try what he told me: take out the battery; press and hold the power button for 45 sec (this will drain the power in the capacitor...they call it "soft reset"); then put the battery back in and try to turn on the mp3 player. That didn't work for me. I just bought this a month ago so i guess because of the warranty, they will send me a brand new one. I hope this help.
Apr 11, 2007 | SanDisk Sansa c150 MP3 Player
Sandisk e130
Get out the battery and let the device "calm down" without any source of power for 5-10 minutes. After that push the menu/start button, hold down for 30 or more seconds and holding down, insert the battery. It has to reset the power circuitry and should help.
Feb 25, 2007 | SanDisk Sansa e130 MP3 Player
Sandisk E250:stays on start up display!!!
I'm having the same problem - to turn it off so your battery doesn't run out, put it on hold.
Jan 24, 2007 | SanDisk Sansa e250 MP3 Player
Freezing
Same problem is mentioned in another location at this site. It happened to me too and nothing works. The standard recommendation is to take out battery and hold down power button for a minute or more, but that did not work for me. Everyone says they took it back which is what I'm going to do.
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
27 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
