Question about Apple iPod nano 3rd Generation
Ipod Problems!!! My ipod wont stop flashing the apple logo screen. It starts up, then it turns off, and so on. I cant even turn it on! i need help!
  • nanao Apr 29, 2008
    I have misplaced my iPod directions on re booting.. Can you help me ?
  • fogel001 Apr 29, 2008
    My ipod wont stop flashing the logo on the screen
How do reset the ipod
Posted on Mar 15, 2008
SOURCE:
It's turning off by self after 1 minute
The Apple iPod may experience technical problems such as turning off and on at random. It is important to note what the iPod does after it turns back on. The main cause of your iPod malfunctioning may be determined by the device's behavior after being powered on.
One simple reason may be that the iPod is not fully charged. Try to see if the battery light is fully charged when it turns back on. The device may turn off briefly to conserve power and turn back on since it is not properly turned off. If the only thing that appears on the screen is the Apple icon and the main menu does not load, you may need to restore the system. Restore b> Apple admits that some iPod products may suffer from software problems. If this happens, the iPod needs to be restored, or re-booted. Apple suggests putting the iPod into disk mode. Once you press the initialize disk option on the disk mode screen, the system will restore itself. Consequences b> All data will be lost if you restore the system. Apple recommends that you have a back up file for all your iPod data before restoring the iPod. How to reset iPod
http://support.apple.com/kb/ht1320?viewlocale=en_us iPod only shows an Apple logo and doesn't start up http://support.apple.com/kb/TS1399?viewlocale=en_US
Apr 14, 2013 | Apple MC525LL/A iPod Nano 8GB - Silver
My ipod says disabled and try again in 21,345,432 minutes..please help
This explains how to do a hard rest on the IPOD, if you haven't tried it already
To perform an iPod Touch hard reset, start by turning the iPod Touch on. Press and hold down the sleep/wake button until you see the Apple logo on the screen. Next, you need to turn the iPod Touch completely off. Press and hold down the sleep/wake button until you see the red slider. Slide the slider to turn off the iPod Touch. This should fix any potential problems you are having with your iPod Touch.
If you are unable to turn off iPod Touch, you can try doing a manual reset. To do so, hold down the sleep/wake button and home button at the same time. Continue to hold them for at least 10-15 seconds. Wait for the Apple logo to appear.
Jul 19, 2011 | Apple iPod touch
I just turned my ipod off and now it wont switch on and i am trying to charge it right now(i pressed the home key and the power key and it just turned black)
Can you see the apple logo or just black screen?
If only black screemn, it means you entered DFU mode. To get out of it, press home and sleep buttons for exactly 10 seconds until the apple logo appears.
Is this iPod jailbroken? If you're stuck on the apple logo, you need Redsnow to boot tether your iPod.
If you're still having problems, your last resort is to restore the iPod which means all your data will be erased. But try the first two suggestions first. Let me know if this works for you. :)
Mar 17, 2011 | Apple iPod touch
Ipod problems
Hi
Actually you are not switch it off it is only for locking the keypads of ipod you cant switch off the ipod
Thanks
T.Boopathy
Aug 26, 2008 | Apple iPod nano
Apple ipod keeps flashing apple logo and cant switchit on or off
if u hav already sorted the problem ignore this
when your ipod stops flashing the apple hold menue+select then as soon as the apple starts flashing again hold select+play/pause for several seconds a white screen should appear, if this happens connect it to ur pc ur i tunes should then reconise ur ipod, u should then restore it
Aug 25, 2008 | Audio Players & Recorders
Ipod has froze
have you guys tried a reset?
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Aug 02, 2008 | Apple iPod nano
My ipod nano wont do anything
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Hope this helps
Jul 19, 2008 | Apple iPod nano 3rd Generation
My ipod wont turn on, I try to charge it but it doesnt even show up on the computer
Can't detect it, won't reset, won't charge, won't play... I reset mine and I had the Apple logo flash at me, and it wouldn't stop. I let my battery die and now my iPod is unresponsive...
May 26, 2008 | Apple iPod nano 3rd Generation
Apple ipod nano 4gb sliver third gen
First make sure your hold switch isn't on. It's on the top and slides back and forth. It needs to be switched to the left. If it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Dec 26, 2007 | Apple iPod nano 3rd Generation
When i turn my ipod on the apple logo come on the screen and then theres a black line and it goes off
try to restore to factory settings if not....u need a new because ur warranty should be up...(not sure)..........once the computer recognise it (disk mode) you can restore. if a screen with an ipod comes up with x for the eyes its done for! (if cant access disk mode)
Oct 24, 2006 | Apple iPod nano
Apple iPod nano 3rd Generation Logo
130 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
