Question about Durabrand DWT1905 TV
Duraband tv no sound
I cannot hear the sound,i can hear it when playing the dvd's only. i have dish sattelite. it was hooked up to comcast cable . why can't i hear it ? there is catv/tv for cable settings what do i do?
  • 3 Answers
Your settings in your tv need to be moved off surround sound and set for standard dolby.
Posted on Apr 03, 2008
SOURCE:
I have comcast cable serice. Do I have to hook up my dvd/vhs recorder to comcast box or just to my tv?
Your tv. You will use your tv "source" to select which input to watch from. Everything goes to the TV. I have a surround sound amp that I run the sound FROM the TV that way if I want it loud I turn that on. It is the only exception.
Dec 29, 2014 | Televison & Video
How do I connect to Sharp HDTV and Comcast cable
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
Jan 07, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
My insignia lcd37 is hooking the comcast modem and works at times. Other times the sound is on, but the picture is blank. Is it worth fixing or just start over.
Okay you TV is hooked to a comcast modem? or do you mean My tv is hooked to the comcast converter box? A no picture but sound you want to first check you cables also try hooking up a dvd to the tv and see if that picture comes on if not and you got no pic and sound this would mean the backlight on this tv is dead or you got a bad inverter not converter, inverter inside the tv. Meaning it needs the repairshop but try and hook up a dvd to it and see if you got picture if so you cable box might be the issue call comcast!
Thanks and please leave valuable feeback and ratings today!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 11, 2009 | Insignia 37" LCD Flat-Panel HDTV
Since i switched to comcast cable and added an on demand dvd box
you have a problem with the cable box. If you have a dvd player hooked up you can play a movie as a test, but I'm sure you will find that the dvd plays fine because the audio plroblem you are describing is a common issue. Also you can try to unpug your cable box power for thirty seconds that will reset it and it may solve the problem.
Apr 05, 2009 | Vizio VO47L 47 in. LCD TV
How do I hook up the recorder
Hi....
Take the output of the Satellite box to the "In from antenna" or "in from cable" then out to TV from the VCR to the TV.
TV should either be on 3 or 4 depending on what the satellite box is set for
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Can't get picture on TV.
If you were using RCA cables, you may have had them hooked up wrong. I know this may sound like an easy fix, but I still hook them up wrong from time to time. Especially if there are more than one set of RCA hook-ups on the back of the unit. If you were using a S-video cable you shouldn't have to use RCA cables, if you had both hooked up that could cause your DVD/VCR unit to not work properly and only get a partial feed to the TV. I hope this helps a little. Good luck.
Jun 17, 2008 | Gateway AR-230 DVD Recorder
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Durabrand DWT1905 TV Logo
53 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
