My power went off too. If I unplug the unit then plug it back in I see green lights on the circuit boards for about 15 seconds and the power light is on in front then it all goes off again.
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 02, 2008
Well it could lot's of problem, first I would suspect bad convergence it's, you will have to insulate what circuit is shutting the unit down, could be over current, over voltage, difflection, convergence, bad power supply, no power (fuse), cold solder joint, when there is no difflection the system (CPU) will turn off the unit to proteck the crt's.
I would first start by syspecting the convergence section shutting down the unit.
Regards
What About Bob
Posted on Mar 15, 2008
Dec 30, 2014 | Sony Televison & Video
on Sep 28, 2011 | Sharp Televison & Video
Jun 05, 2017 | Hitachi 62VS69 62" HDTV
Nov 28, 2010 | Hisense LCD1504 15 in. Television
May 23, 2010 | Vizio L32 32 in. LCD HDTV
Dec 28, 2009 | U-Line 2115R Echelon Series 15"...
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
Aug 28, 2008 | Proscan 19LA25Q 19 in. LCD Television
Feb 15, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Jan 06, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
167 people viewed this question
Same happens to my TV. I unplug, then plug back in. The LEDs on the circuit board light up for a few seconds then everything turns off.
when replugged led in front comes on after 3-4 seconds for coupla seconds then shuts down
same thing
