Thanks for your help,
I have a Sanyo AVM-3289G Television that I am trying to repair. As the plug is being inserted into the AC outlet the polarized leg sparks. Once plugged in there is a faint, slow ticking noise I am not able to trace. The symptom that caused further inspection is when the power button is pressed the television sounds as if it is firing up. However, no picture or sound and it powers down immidiately. I appreciate any help. Thanks again. -Chris
    Genius:
  • 1,153 Answers
Probably Horizontal output shorted, you would need to check the 3 leg transistor on a heat sink to see if shorted.
Posted on Mar 15, 2008
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
We turned it off, went to bed, this morning nothing works. we replaced batteries. tried manually. nothing. Plugged into wall outlet, new house. It's a Sanyo, VIZON, HGTV 48" flat screen bought at...
My personal suggestion would be to go for these repair
catalogs. I know this website reliable-store that i used to buy them from, and they sold online it was very good manual. Go ahead, I bet.
Mar 05, 2018 | Sanyo AVM-2756 27" TV
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
Jun 06, 2010 | Sanyo AVM-1909S TV
AC adaptor positive or negitive
look on the adapter part that plugs into the wall outlet and it will show you what polarity the center pin is
Dec 24, 2009 | Samsung HLN5065W 50" Rear Projection...
Sanyo TV
every time i plug tv in outlet it blow the fuse inside tv board
Jul 01, 2008 | Sanyo AVM-3259S TV
SANYO AVM-3289G no vertical deflection
It isn't a transistor, It will be an I.C. with a part number that probably starts with an LA_ _ _ _ . It will be on a heat sink and be in the vicinity of the connector going up to the yoke. Try replacing that. But first, check all the electrolytic caps around it for testing dry (sorry - takes a special meter to do it in circuit) or just replace them. May have lost power to the I.C. as well. Look the I.C. up in the free NTE crossreference at nte.com get a diagram of its pinout to find what pins the power and outputs are on.
Dec 14, 2007 | Thomson 28VK25US TV
Sanyo monitor no sound
were it mine I would just replace it with a bigger /better one. 10 years is a good life
Sep 09, 2017 | Sanyo AVM-1309S 13" TV
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
