Question about Kicker Solo-Baric L5 Car Subwoofer
Kicker L5 solo baric
I am trying to wire the speaker inside the box and it has two neg terminals and two positives on each speaker. how do i connect each speaker inside the box to run it to my 2 channel amp
  • Anonymous Jul 20, 2008
    how do i wire the speaker correctly
Wire the speaker in series and bridge the amp
Posted on Mar 16, 2008
I have 2 15 inch L5 solo baric subs and need a amp?
the 15" l5 is rated at 750 watts rms so i suggest you get an amp with atleast that much power because if you get a amp weaker than that you run the risk of clipping your subs and blowing them
Jul 15, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Como conecto 3 bocinas l5 de un cajon a un amplificador
Firstly, lay all 3 speakers face down next to each other. Note the connections +- +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the center speaker(+). Take the center speaker (-) and connect to last speaker (+). The last terminal(-) will go to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
Jun 03, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i wire a solar baric l5 to a planet audio 999w amp?
You should bridge your speaker on the amplifier. Check your connections on your amp. Normally it will be the - (Minus) on the left channel and the + (positive) on the right channel
Mar 20, 2010 | Kicker Solo-Baric L5 Car Subwoofer
How do i wire a kicker l5in the box
did you build the box yourself? because ones from the store have ports in the back of the box. all you do is run a wire from the sub to the ports in the back of the box, which on the outside is connected to the amp.
Jan 02, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Solo baric L5 just stopped no warning or sound of it blowing
looked at the wires going into the subb might have pulled one out look je
Nov 13, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Wire broken off cone duel voice coil looks like black terminal
there isnt really much you can do, you can try and solder it but you take a chance of burning the speaker. it is best just to replace!
Oct 25, 2009 | Kicker Solo-Baric L5 Car Subwoofer
How do you wire l5 to 2 ohm
Hello lholt07,
If the L5 has 4 ohm voice coils, you simply wire both voice coils in parallel, both marked and unmarked positive terminals together and to the amp and likewise with the negative terminals. If the L5 has 2 ohm voice coils, it cannot be wired to 2 ohms.
Hope this helps.
Sep 19, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Bad sound while playing at low volume, tested both voice coils and they are both are around 4 ohm.
do you have it wired down to 0 ohm or 2ohm if u have a mono block amp wire it to where a pos. from one side goes to a neg on the other side and then use a pos an neg from diff sides coming from amp
Jul 30, 2009 | Kicker Solo-Baric L5 Car Subwoofer
How to wire my kicker solar baric
All depends on your amp. Is it 1 ohm stable or not?
Parralell:
positive (pos) on voice coil 1 (vc1) to Pos on vc2 and negative (neg) on vc1 to neg on vc2. Then speaker wire from amp to one vc only = 1ohm load.
Series:
Pos from amp to Pos on vc1. Neg of vc1 to Pos of vc2. Neg of vc2 to amp = 4 ohm load.
Jan 21, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Rebuild
what kind of re build?
Oct 12, 2007 | Kicker Solo-Baric L5 Car Subwoofer
Kicker Solo-Baric L5 Car Subwoofer Logo
253 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
hoyzee1
Marvin
Marvin
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
