Question about Panasonic KX-TG2740 Cordless Phone
Got instruction to unregister KX-TG6074B
Got any instruction to unregisterKX-TG2740 without old handset?
my base is broken, and I bought the base from ebay. This base has all 4-phoen registered before, and it doesn't accept anynew hs.
If this error message displays on your handset, please follow the instructions below to deregister your old handset before registering a new handset.
1) On the base unit:
Press: FUNCTION or PROGRAM
Button name varies by phone model.
2) Press: MUTE
3) Enter the numbers 3, 3, 5, #
4) Enter the handset number (1 to 8)
Posted on Jun 10, 2008
Thanks for the reply, I did get the solution from Panasonic support group (worked!). Here they are:
1. Unplug the AC Adaptor from the back of the main base.
2. Hold down the LOCATOR button, while plugging the AC Adaptor back.
3. Once the base indicator lights come back on, release the Locator button.
4. After less than 5 seconds, hold down the LOCATOR button again until you get a long beep.
After doing the above procedure, you may then register your handsets to the base unit by following the instructions on page 39 of the manual
Posted on Jun 13, 2008
No Link to Base - - Walk closer to base and try again --
You should try resetting both the base and handset but removing their power supply/batteries and then reconnecting their power supply/batteries. You can also check and see if there is a registration option on the handset that will re-link it with the base. Could just be broken though!
Jan 08, 2014 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TG2740
u have to try change battry its might be week so try it
Sep 08, 2008 | Panasonic KX-TG2740 Cordless Phone
I bought a used handset for my Panasonic wireless phone system, and now it is still registered to the original base and won't communicate with my base unit. Handset is KX-TGA931T and base is KX-TG9331T. ...
They are correct - the phones are married to the original base and can only communicate with that unit since they share frequencies. Other handsets have different frequencies ans will not work
Sep 20, 2017 | Panasonic KXTGA931T Cordless Expansion...
Phone keeps saying move closer to base
The handset may have unregistered from the phone. The instructions to reregister it are in the manual, but I'll list them here for you.
1. On the handset, press MENU 001
2. On the base unit
For models KX-TG6021/KX-TG6022/KX-TG6023
Press and hold LOCATOR until the IN USE indicator flashes.
For models KX-TG6051/KX-TG6052/KX-TG6053/KX-TG6054
Press and hold LOCATOR/INTERCOM until the IN USE indicator
flashes.
After the IN USE indicator starts flashing, the rest of the procedure
must be completed within 1minute.
3. Press OK on the handset, then wait until a beep sounds.
4. Press OFF on the handset.
Aug 29, 2009 | Panasonic KX-TG6021 Cordless Phone
Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Dec 16, 2008 | Panasonic KX-TG2740 Cordless Phone
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
Deregister lost or broken phones
Some tricks from a helpful Uniden rep:
holding down end+# keys at the same time on the phone for about 10 secs (you will hear a beep) will deregister the handset. If you have a dead handset and want to deregister it from the base, you have to reset the base. unplug the phoneline and power. hold down the "delete message" key, plug power back in. about 10 secs later, you will hear a long beep (theres a short beep upon powerup as well). At this point all handsets are deregistred and you will have to reregister them with the end+# trick. this way when #1 handset is dead, you can make a working one #1 and get the broken one fixed emotion-1.gif
BTW, this is a woot warranty, not uniden warranty. however the uniden rep gave me the number to the people who refurb (rox0rz!) these. I'll post an update when I finally get ahold of them (and the number if its actually helpful)
Jun 20, 2008 | Uniden TRU8885 Cordless Phone
DeRegistering a Damaged Cordless Phone????!!!!
If you are still looking for an answer on dereg of a handset, the manual says Menu - 0-0-2 then 3-3-5-OK then select the handset you want to cancel/deregister
Nov 05, 2007 | Panasonic KX-TG6074B Phone
DeRegistering a Damaged Cordless Phone???!!!!
I have a Panasonic KX-TG6700 base unit and KX-TGA670B handsets. We had a similar problem where we were no longer able to deregister the handset using the handset itself. We wanted to be able to use that slot that the broken phone was still occupyng. The solution that we found in the manual online was to hold down the intercom button for 3 seconds until the "in use" light turned on. Then press and hold the number of the extension you want to deregister until it beeps. At this point the base unit has freed that extension.
Nov 05, 2007 | Panasonic KX-TGA600B Cordless Expansion...
Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Oct 18, 2007 | Panasonic KX-TG2740 Cordless Phone
Panasonic KX-TG2740 Cordless Phone Logo
613 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
