Question about Panasonic DMR-EH55 DVD Recorder/HDD Recorder
Hard reset im having the same problem with my dvd player, after copying from the hard drive to disk it comes up with an error saying there maybe a problem with the disk and to push enter to restart and error check but it doesnt work. Is there a hard reset button? I really dont want to loose whats on my hard drive tho. any help appreciated, thanks!
  • Anonymous Mar 25, 2008
    I too am having the same probs. It won't play DVD's either. It accept any recordable DVD's
    Problem Solver:
  • 11 Answers
If you put a disk in and all it does is click several times, it's more than likely the spindle motor. It's best just to replace the DVD drive. Recording in the default high speed mode tends to cause the spindle motor to fail over time. Usually in a very short period of time. It's best to set your record speed to the standard mode to avoid premature failure of the spindle motor.
Posted on Apr 09, 2008
Troubleshooting error codes 0x80130701
this is the answer from a Microsoft engineer:
I would also suggest using a different DVD drive, or maybe copying the installation files to a USB stick (4gb or bigger) and performing a USB install. The error 0x80070017 translates to "CRC Error" which means that the files that are being copied from the disk are not making it to the hard drive with the same structure, meaning that the "original" files on the disk are being modified/changed/corrupted while being copied to the "destination" location on your hard drive during the install.
This usually means either a bad DVD, or a read error on the DVD drive.
The easiest thing is to make a USB drive to install Window s7 (and it's WAY faster than DVD too!)
http://technet.microsoft.com/en-us/magazine/dd535816.aspx
I hope this helps. I suggest (if you have a back-up copy) to burn a new copy of your install DVD. The present one cannot be fully read by your drive. With the new copy it will work fine as long as your DVD Rom is in good order. The USB install depends on you having a good copy of the software to load on the memory stick anyway. I think that's it all covers eh ? Good Luck, Ray.
I too hope it helps
Jul 08, 2014 | Microsoft Windows 7 Home Premium 64BIT...
I have an rsq 787 320 gb have been adding my songs am at 2252 started adding at 456 it wont add anything more.It say copy cancel disc reader error.I has just had a new hard drive put in it came with 3000...
first find out what parts are failing, the disk?
what disk.? what OS,
do a full scan disk test on disk , if it is corrupted, then, it is.
came with 3000 songs.?
that sounds like a fairy tale to me, nor legal.
if its your backup drive, then where is your alternate BU?
backing up to only 1 device is not going to work,
burn a DVD and burn a flash stick too.
there are recoversoftware that can recover data and skip over the bad. for sure.
Sep 25, 2013 | RSQ HD-787 320GB Hard Drive Multi Format...
Please insert a disk into drive
You can only copy files to a blank disk by using programs like NERO or by using a re-writeable disk like DVD-RW which you can format and use it like a hard drive. You need also burner not an ordinary DVD or CD player.
Aug 07, 2008 | Computers & Internet
Errors burning to 1x to 16x DVD-R
I have had much luck recording on off brand 16X discs as follows:
1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
3) After a minute or so, window will come up and say "Cannot
complete copy."
4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
6)Let me know if it works for ya. JGIDUSKO@CFL.RR.COM
Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
Disc read problems....
The problem may lie with the format of the disk, is the disk a
DVD-R -, or a DVD-R+?. if it was a bought DVD, it may be the wrong regon (i dont know how to spell the aforesaid word), a bad copy, a dirty reader, a dusty DVD, or your player.
thats all i can say
Mar 10, 2008 | Sansui VRDVD4005 DVD Player/VCR
Coping dvds ,cds
If you are copying a DVD to another blank DVD, just put the original DVD inside > open Nero > click Copy disk > then the copy dialog box window will appear. > Just select your favourite speed ( [8x] medium speed recommended) and click Burn. If you are copying a DVD to your hard disk, just put your DVD on the drive, Open My computer > right click DVD drive icon and click open > Then select the appropriate file or folder to copy > right click it select copy > close the window. Now open My computer > open disk drive [may be D: or E:and so on... ] > right click and select paste. Now the file will be copied to your disk.
Sep 29, 2007 | Ahead Software Nero 6.0 (60045) for PC
Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Feb 01, 2007 | Daewoo DVRS05 DVD Recorder/VCR
Problem with burning dvd on imation dual layer dvd burner
You seem to have a related problem, you can't burn cd's and you cannot install windows without an error. Either your hard drive has a bad sector where it keeps trying to write the data or your dvd drive has a reading error. Firstly check your hard drive for errors, right click on your 'c' drive and down to properties, then click on tools tab, then error checking. This can take quite a while, so be patient. Secondly, there have been numerous updates from Nero especially related to Service Pack 2 so download the latest updates from their 'Ahead Nero' website, they are free as you are'nt upgrading just updating. Your ratings are important
Nov 23, 2006 | Imation (01932) CD-RW Burner
Panasonic DMR-EH55 DVD Recorder/HDD Recorder Logo
830 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
