Question about Sony Cyber-shot DSC-W55 Digital Camera
Focus on zoom
My wife dropped the W55 and the lens assebly was loose.  I sent for a new Optical unit with the zoom motor included.  I replaced it without incident and it seems to look good on the LCD, but when I zoom it in the picture returned/stored is blurry.  It seems like there is a lot of movement to it, but I was holding still.  Is there any adjustment that I need to make?  The CCD was not included so I just swapped it from the old one.
  • 104 Answers
It is not the ccd problem .
the lens adjustment and ccd have no relation.actually when optical unit was replaced ,it is not fixed properly and due to internal lens de-adjustment.you would find blurry images on zooming.
it must be re-adjusted.
Posted on Mar 15, 2008
I have an Olympus digital camera and the preview shows blurry screen, I can't take pics, how do I fix this?
Appears that the focus motor is not working. Part of the optical lens assembly which as has a focus, zoom, and exposure motor to control all.
Replacing that assembly in the camera is nasty and expensive due to just the labor alone - and the part is not cheap! Think you are better off replacing the unit - not cost effective.
Jul 13, 2015 | Olympus Cameras
How can I fix the autofocus on my Quantaray 7-300 lens.
Sorry to say but the lens needs to be sent in for repair. To repair or replace the AF motor is usually around the $200.00 range. Do not try to fix it yourself.
Sep 07, 2014 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
System error focus
you hve probably damaged the lens unit. impact while the unit was extended? the auto power off will retract the lens thus damaging the little plastic gears in the lens unit. you may need to replace the lens unit
Dec 18, 2013 | Panasonic Lumix Dmc-fh1 12 1 Mp Digital...
Samsung SC-D363. Dropped about a foot while sitting on bleachers at school gym. Now it will not focus. I can zoom in and out, it is blurry, except at one spot in the middle of the zooming where it comes...
Hi J,
Fixya makes me laugh sometimes. I've been a camcorder tech for 25 years. There are two movable lenses inside the lens assembly in your particular. Both are motorized, the zoom and focus lenses. What has happened is that the focus lens cannot move. If you are handy and very careful, you can take the camcorder apart and fix it. Label your screws, there are different thread types and legnths. Inspect where the optical unit plugs into the main board. Make sure it's plugged in fully and neither connector is partly torn from it's board. If that is OK, remove the optical assembly -there are two screws that attach it to the main board. Inspect the ribbon cable that wraps around the optical assembly for tears or other damage - particularly where it runs to the focus motor. If all is ok remove the focus motor VERY CAREFULLY so as not to damage the ribbon and look inside the lens assembly. You will see a little spring loaded plastic arm that runs back and forth on the worm shaft of the motor you removed. It is likely popped askew or off the lens bracket. You need to use a very small screwdriver or dental pick to pop it back into its correct position. Make sure the lens can move forward and back freely through it's range of motion. Reassemble everything, being careful to fit the little arm onto the worm shaft of the motor. That should fix you up!
Aug 19, 2011 | Samsung SC-D353 Mini DV Digital Camcorder
The autofocus is not working. I tried going to manual focus and this won't work either. Also when I try to zoom out it will only let me go about a qauter of the way then it stops, and won"t zoom out...
Was it recently dropped or bumped in any way? The focus and zoom motors are not activating or limiting. It could be misaligned or slipping gears. Listen for motor running as you press the appropriate function - such as manual focus or zoom. If you hear anything then the motor are running but not adjusting the lens - therefore the gear is loose and/or the motor is slipping. It must be taken apart to repair.
Nov 11, 2010 | Hitachi DZ-MV350A DVD Camcorder
My new Cd-player is skipping on every cd disk
If is possible that either the holding lid to the spindle is wobbling or that your laser is mistuned., You can open the set and check for low setting of the main spindle, lift this if the lid is too much to the bottom of teh motor. Next check for dirt or particles in the Cd mechanism and the optical lens. clean and check. If not the lase need to focus more for the data to be read. for this you will need acess to the rear of the optical unit and should be done with an anti static tool. Attempt to do this only if competant with such electronics circuits. Since you mentioned new I believe if there is warranty to claim for this optical unit you must do so rather than waste by tampering. So go and make a claim or call up the dealer to confirm. If no help is coming you might need to change the optical unit assebly. Hope the Cd's you have played were good one. Helpful? Good day
Jul 15, 2010 | JVC Audio Players & Recorders
When the camera is turned on , the zoom tries to adjust twice while the displays says" access" then it Says" Turn the power offand on again" Following the instruction does not solve the problem, we can see...
The error "Turn off the power and on again" shows when the zoom motor start malfunction, If you want to repair by yourself and have experience then change the optical zoom motor it will reduce your cost. Otherwise you can change complete lens block assembly, both part and description is given below for your help and convenience:
Part No. Description
1-788-363-11 OPTICS UNIT (ED13A) (complete lens block assy)
2-673-648-01 ZOOM MOTOR UNIT
You can contact any expert or Sony Service Center to change the above said part and your camera work fine again.
Thanks for using fixya.
Jul 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera cant take pic.
HI,
    The optical lens bolck assymbly need replacement,Because the zoom motor get malfunctioning.For this you have to contact any SONYSERVICE CENTRE nearby to you.
 Thanks and dont forget to rate.
Nov 24, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Problem with focusing
sounds as though the focus motor worm gear is binding up. I have ,at times been able to take this assebly off the zoom lens ,oil it and reinstall it. very very light amout of floil, a very thin oil. Also the zoom motors worm gear binding will cause this problem, sometimes one of these motor/worm gear assemblies will have to be replaced.
Sep 15, 2007 | Panasonic Palmcorder PV-GS120 Mini DV...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
