Install sound device - Audio Players & Recorders
I need audio device
Posted on Mar 09, 2009
6ya staff
SOURCE:
How to i instal sound drive for my pc?
Hello
1. Power on your computer. Ensure that there is a sound device installed on your computer. You can locate your sound device by right clicking on "My Computer." Click "Properties." Select "Device Manager." Click on "Sound." Your sound device should be listed. If there is no sound device listed, you will have to purchase and install a sound device before proceeding.
2. Insert the CD or floppy disk that contains the drivers for your sound device into your computer's CD-ROM or floppy disk drive. If you do not have the CD or floppy disk that contains the sound device drivers, there are websites such as Driver Guide and NoDevice that will allow you to download the drivers online for free.
3. Click on "Install Drivers." The sound device drivers will then be installed onto your computer. It may be necessary to restart your computer once the installation is complete.
4. Open your media player and play an audio file to ensure that your sound device drivers were installed successfully.
THANK YOU
Jan 28, 2011 | Microsoft Windows XP Professional for PC
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Dec 12, 2010 | Toshiba Satellite M35X-S114 Notebook
No sound , sound drivers are working
Most common reasons for this trouble are:
  • Such kind of troubles arise after some device / software is installed which tries to gain control as default sound device.
  • Also while un-installation of certain softwares, some shared files are removed. At times some important shared file can be deleted which causes troubles with working of sound drivers.
  • While installing certain games, it tries to gain control of sound or video drivers and may accidentally harm these driver softwares.
Lets see the ways to fix such troubles
Step1 : First of all check what is your default audio device setting. For this, open Control Panel > Sounds and audio devices, open Audio tab as shown in picture below.
See that the Device selected is your sound-card or on-board audio device. It should not be blank or some modem device. Set the Default sound playback and sound recording device correctly from the drop down menu. If your device is not there in this list see the step 2.
Step2: If the step 1 is not successful, it means that your sound device driver software has become either corrupt or has been accidentally un-installed. In such case, install the sound driver from the sound-card/mother-board driver CD. You can also download the latest driver if you don’t have the driver CD. After you install the driver, restart your computer, and then check the settings as in step 1 again
Jun 01, 2010 | Microsoft Windows XP Home Edition
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
Cant get any sound out of my laptop
Check whether the sound card drivers are installed properly or not. If installed check in the device manager, go to device manager and navigate to sound and audio devices. Check if the drivers are installed correctly.
Oct 18, 2009 | Computers & Internet
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might...
You might encounter this error message for one of the following reasons:
  • Your sound device is in use by another program. Quit other programs that might be using your sound device, and then try to play the file again.
  • Your sound device requires an updated driver. To determine if an updated driver is available, see Windows Update, or see the sound device manufacturer's Web site.
  • The selected sound device does not support Secure Audio Path (SAP). If you have multiple sound devices installed on your computer, try using a different one.
  • Your sound device is not functioning properly. To troubleshoot the problem, see Windows Help and Support or refer to your sound device's documentation.
  • You do not have a sound device installed on your computer. Install a sound device (such as a sound card), and then try to play the file again. If you can't install a sound device in your computer, you might be able to resolve the problem by attaching USB-based headphones or USB-based speakers to your computer instead.
SOURCES- WWW.MICROSOFT.COM
Apr 26, 2009 | Razer BARRACUDA AC-1GAMING SOUNDCARD 7.1...
No sound device
What is your motherboard type and model? If you purchased your computer a brand new unit,a CD installerforit device drivers shouldcome with it. If you have that Device driver installer CD,try installing from the CD device installer that came with your new PC.
Apr 18, 2008 | Computers & Internet
Sound device
Here's a link where you can download the audio driver for the Presario 5000. Download and install this file.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=92867&lang=en
Dec 23, 2007 | Compaq Presario 5000 PC Desktop
Sound device
The reason for the message will be the fact that windows doesnt recognise that there is a sound device available because the driver for your sound card or onboard sound is not built into XP and therefore you will have to find out what make of audio you have and install the relevant driver.
Aug 24, 2007 | Microsoft Windows XP Professional With...
127 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
