Question about Nokia 3230 Cellular Phone
Nokia 3230 when i press power botton a white screen comes up with no nokia sign and start for a while then shut down. i dont know di flash file to get and where to get them?
  • Anonymous May 09, 2009
    it keep on restarting..even i turn it off... i dont know why?? so pls help me...
Contact any retailer to flash your mobile.....
Posted on Apr 15, 2008
Need to factory reset
With the phone off hold vol - and power buttons until recovery screen comes up. Then use vol buttons to move up and down and power button to select.
Nov 28, 2015 | ZTE Cell Phones
Screen goes blank after windows corporation logo
perhaps you need to reinstall the operating system,the system files might be corrupted because of power problem,and there's "windows loading files" thing,so the windows cannot go further because it cannot find some files while loading. do you need any help with installing operating system?
Aug 25, 2012 | Toshiba Satellite Pro L300 Notebook
Nokia 2700 display a white screen and turns off. how to repair it nothing is visible.
It seems that your phones firware has corrupted.you musttake it to the service store or if you are good enough with computers,followthese instructionsFirst download and install Pheonix. NokiaPhoenix Service Software 2011 -Download secondly Download flash file from this link Nokiaflash fileandinstall it to C / programme files/pheonix..afterfinishing this installationopen pheonix Inside theinterface at the> left top File" click there and choose "openfile" and then select the appropriate Product type i.e"whichis written in the back banel inside the battery of every Nokia(Type RM-000).Afterdoing this again at the left top count from "File"1..2..3..the 4thone is "Flashing" press there when you click there you'll seethreeicon just select the "Firmware Update" again you'll seeanother interface .Look at the product code there should be blank and put your "mousetool" at the straight end from the "Product Code" thereis a Botton and choose the code which is written in the back sideof your phone. e.g CODE:0000000.if the same code does not found, justtake one.After this you can see "Dead phone USB flashing" clickthat box .Now this is the last stage... Connect your phone with the USBtoyour PC and let the driver install ...wait for a moment.(If yourphone working).Lastly after just finished (In case your phone isDead,unable to switch on in normal mode start from here) Connect thephone to pc without powering...insert good battery and Click the "Referbish"afterthis, a message will prompt you "press power botton"press it and wait untill the phone will Restart automatically
Oct 25, 2011 | Nokia Classic 2700 Cell Phone
When I switch on my Nokia 3110c, the screen flashes 2 or 3 time and shuts down. What could be the problem? and how can i rectify it as early as possible
First of all remove sim card, memory card and reboot the phone for 3-6 times.If the problem still persist you need to flash the phone.So contact mobile repairing shop or follow the procedure below
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 23, 2011 | Nokia 3110 Cellular Phone
Phone is freezing at start up and cannot be turned off
hi,
your phone is having corrupted software,you have two option to fix that..first if you have this gadget you can do it it on your own...
1.) activated mx key dongle with ufs interface
2.)ufc cable
3.)5800 flash file ,MCU ,PPM ,CNT
here is the procedure,
A.) open mx key
B)connect the phone to mx key using ufc cable
C.)bus scan
D.)if the phone is now connected and you read the info
E.)put mcu ,ppm and cnt (warning ,the flash file must be higher than former version because 5800 is undowgradedable,to prevent more damage on its software...
F.)back up rpl and pm before fllashing (in mx key thick SERVICE <IMEI AND SECURITY ,ALL SECTION
G.)the phone is now safety for flashing ,then wait until its done...
if you have no gadget and tools that i mentioned above ,go to a nearest nokia care in your place ..i hope it will help you ,thanks for trusting fixya
Jun 19, 2010 | Nokia 5800 XpressMusic Smartphone
The laptop loads up, lets me sign in, then goes blank, no icons
Try booting to the safe mode (F8 at boot) and see if you can log in via the safe mode. If you can't, try booting to your Windows CD, go to recovery console and run CHKDSK /R
If you still can't log in, try running diags see if the hard drive lists a failure.
if no hardware failure found, there and none of those solutions work, then re-installing windows will likely be the final resolution
Oct 06, 2009 | Dell Vostro 1500 Notebook
Down load web file it says that web memory eull
Your phone memory is full'
that's why your phonbe can't install or load the settings for the web.
Re-format your phone'
but b4 formatting it. all the phonebooks, massages, pics., will be lost or deletted.
but not the memory card will remain all the files inside.
How to reformat your phone here'
Check your batt. if is full' or 3bars charge.
remove the sim and memory card.
here how...
Press this all bottons. (the power botton, The * botton, the 3 and the green or call botton.
(power, *,3,call botton at the same time.)
the phone will turn on' and after the NOKIA logo you will see a formating... inthe screen of your phone wait untill it finish and reboot.
I hope it will Fixya your problem.
Aug 31, 2009 | Nokia 7610
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
N 70
try to HARD RESET FORMAT
make sure your battery is more than 3bars,
just press the green botton, 3 ,* and power botton at the same time.
Don't release it until you see the Nokia blink and the screen turn on white' and then release all the botton you press.
wait untill your phone re-boot.
hope it will fiya your prob.
thanks for rating this solution.:D
Mar 11, 2008 | Nokia N70 Cellular Phone
Power on/off problem
format ur phone by using code * + 3 + Call key + On/Off key till formatting appears, if this does not work u have to flash ur phone
Dec 14, 2007 | Nokia 7610
Nokia 3230 Cellular Phone Logo
99 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
