Question about Kenmore 22422 Top Load Washer
Kenmore 70 series washer
How do I put the agitator back on, it fell off and seems like nothing is broke,
  • Gary Davd
    Gary Davd May 11, 2010
    pop off the cap and there is a single bolt you need to tighen down if it is not striped
  • 105 Answers
Check securing bolt on adgitator sometimes the bolt will strip out in main stem may need to tap out and fit new bolt
Posted on Mar 15, 2008
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Mar 27, 2009 | Kenmore 22422 Top Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
67 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
