Question about LG KU990 Viewty
Unable to switch on beyond a faint blank screen no matter what I do to reset it
  • 3 more comments
  • Anonymous Mar 18, 2008
    hour glass is turning but phone is not powering on or off
  • Anonymous Mar 24, 2008
    Have removed battery and sim card for several hours but blank screen still appears on start up. Sometimes actual screen will come up but it is random. Haven't found any remedy as yet.
  • Anonymous Apr 01, 2008
    Unfortunately, has exactly the same problem. I have removed a software and WM5.0 asked me to restart. Since blue screen with ASUS logo appears and after 10 secs blank screen appears forever. No solution found :-(
  • Anonymous Apr 03, 2008
    so often i had difficulties firing up the hpone htc p3450, so often it's only until the logo window then goes blank, other times when switching on a green text smart mobility frozen on the sreen reset then it's gone and back to the same prob of firing up, rebooting by removing the battery and back on will solve the problem, but it on a few time work...while browsing the net suddenly hang or frozen. resetting using the stylus and again back to where the problem start...good luck.
  • subbie May 27, 2008
    once i replace the battery it turns itself on and then it goes to a screen that has a small rectangle with a circle,square, and a triangle in it with a large cirlce with a line thru it over it then it has 507 under it and it will not do anything else. the power wont turn off or anything it just stays that way what do i do?
Serial at the top and v1.06 at the bottom
and my usb base is dameged
Posted on Mar 15, 2008
Why is screen blank?
You never said if it worked with external monitor. You also didn't say if you tried the [fn]+[Fx] key combination on the keyboard to try and switch displays.
But, if you look at the screen closely, at an extreme angle and can faintly see the graphics then that means the backlight has blown out. For the displays with LED backlighting it's usually just a wire or circuit to repair. For the screens with CCFL (fluorescent) lighting it's a simple matter of replacing the inverter board.
Mar 14, 2016 | Samsung NP300E5A 15.6 Laptop i3 2.4GHz 6GB...
My Samsung TV has only a faint picture and full sound.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - The RCA TVs generally only have a 1 year limited warranty so that ... LG LEDLG LED TV has no picture (black screen) but still has sound TV has ... I Have SAMSUNG UA46 F6400 LED 3D TV I want TO CONNECT MY ... SolvedSamsung ledTV no picture solution; Sony vizio led tv has faint picture solution ...
TV Has Sound But No Picture Troubleshooting Guide ...
? 2:30
https://www.youtube.com/watch?v=ysHfaQKI45M
Aug 31, 2012 - Uploaded by Repair.com
Here are some steps to ease you through TV picture loss-from prevention ... But now when I turn on the tv there only sound nopicture. ... had sound etc. with very very faint picture if you look very closely (which I was). .... How To Fix Samsung LCD TV -Samsung TV Repair (Blank Screen) - Duration: 9:21.
Samsung LCD TV No Picture but has Sound - Electronics ' DSLReports ...
www.dslreports.com > ... > Electronics
DSLReports
Jan 26, 2016 | Samsung Televison & Video
BLANK SCREEN..NO SOUND OR PICTURE ON MY SANYO 50" FLAT SCREEN TV...MODEL NO: DP52440 HOW DO I RESET IT
Try unplugging the set from its power source, let it sit for 10 minutes and then plug it in again, then turn it on. Are you getting any on-screen messages or logo display when you turn it on? Is there any backlighting showing? (in a dark room, the screen should have a faint glow). Try switching the input source using the remote. If the set is less than a year old, it is under warranty. If nothing is displayed ever on screen, the panel might need repair or replacement.
Jan 28, 2015 | Sanyo Televison & Video
Blank frozen screen
IF IT IS A TABLET...
IT WILL SURLY HAVE A RESET BUTTON,RESET YOUR TABLET..NON OF YOUR DATA WILL BE LOST...
Dec 25, 2013 | Cell Phones
Am unable to see anything on Samsung 740N monitor
the inverter which sends a signal to the lcd is either bad or the cable inside is loose.
good luck
Aug 26, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
I am unable to starat the lptop
1. check your laptop charger, if your charger
have some problem then your computer
behave so,
2. Backup all your programs
3. Re-format your system
this problem will not occur frequently.
thanks.
Jun 16, 2009 | HP Pavilion dv1000 Notebook
Laptop screen blanks out
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 02, 2009 | EliteGroup ECS G900 Notebook
Laptop screen goes blank
try a live cd and if it doeasn't work on it then ur screeen is dead.
P.S.
live cd=bootable cd
you can download it from linux.com
Apr 01, 2009 | EliteGroup 536 Notebook
Flash blank white screen
your mobile need to be reflash take the phone to a mobile center and have it flash or you can do that online at www.topsony.com and this is not a free site
Jun 20, 2008 | Sony Ericsson Walkman W810i Cellular Phone
LG KU990 Viewty Logo
69 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
