Question about Refrigerators
I have an old westinghouse frost fre 422, it works but blows warm air, is this fridge worth anything as spare parts
    President:
  • Refrigerators Master
  • 2,651 Answers
Problably worth more as scrap metal honestly
Posted on Mar 15, 2008
6ya staff
SOURCE:
Fridge is warm freezer is cold
Hello Abo Karin,
You are likely experiencing a DEFROST failure
(most commonly a defrost PCB failure)...
part number 67006740 item 5 on your exploded
case view (top center as viewed from the front).
There are typically only three (3) elements to a DEFROST
power control circuit:
- Defrost Printed Circuit Board ( PCB as noted above)
- Heater element to WARM the EVAPORATOR
- DEFROST thermostat... inhibit excess heat
(closed circuit at freezing - Opens at room temperature)
Check your defrost pan...
there should be water there DAILY...
IF not: you are assured that your DEFROST fails.
Per your DESCRIPTION...
You need to look for a SUDDEN REASON (huge air leak)
why FROST would form so quickly...
USUALLY a big pizza box... BUT ANYTHING blocking a
TIGHT DOOR SEAL will cause massive frosting.
It is taking moisture from the WARM ROOM AIR and blocking your evaporator...
a PROPERLY functioning defrost circuit would remove that frost
at least DAILY... and the EVAPORATOR fan would properly chill the refrigerated side blowing cold air from the FREEZER.
Yes ... all INTERIOR panels must be in place for the refrigerator to function properly.
Hope this helps
Your part... (see video instructions)
http://www.appliancepartspros.com/whirlpool-board-jazz-wpw10503278-ap6022400.html
Sears... (I don't USUALLY recommend for purchase)
http://www.searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Refrigerator-Parts/Repair-Maintenance/Questions-Answers/location-of-defrost-timer-on-sears-fridg/Model-59665932402/0582/0161000/338616?modelNumber=59665932402
also see other .com retailers
partsselect,
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Apr 19, 2017 | Kenmore Refrigerators
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
White Westinghouse ( Model# MRT 18FNEWO
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 24, 2011 | Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Fridge is 12 years old or so and freezer has been icing up. The fridge is now suffering from global warming and is near useless, being the same temp as the outside air (it's summer here in NZ, yipee!). But...
IF THE FREEZER HAS FROST AND ICE NO COLD AIR WILL BLOW TO THE REF SECTION, YOU MAY HAVE A DEFROST ISSUE. UNPLUG THE REFRIGERATOR OVERNIGHT THEN TRY TOMAROW IF THIS WORKS IT WILL FROST UP AGAIN UNLESS YOU CAN LOCATE WITCH DEFROST PART IS BAD.AND REPLACE IT. HOPE THE SURF IS GOOD! ANYHOW
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Refrigerators
Freezer cold, fridge part cold at first then warming
hi friend
it is fan problem check it....it may also be a thermostat not working proper,,check them both ,
thank u,,,,,,,,
May 03, 2009 | Estate TT18TKXKQ Top Freezer Refrigerator
Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Apr 18, 2009 | Westinghouse Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
