Question about Nintendo Wii Console
Wii Turn on
When ever I turn the wii on the power button turns green and then automatically shuts down, it doesn't even go red
You should chech the power slot or maybe you press it to many times.
Posted on Mar 14, 2008
Wii power light is flashing red
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
Dec 29, 2012 | Nintendo Wii Console
Is there a master reset on the wii
Instructions
    • 1
      Locate the "reset" button on the front of the Wii console. Hold it down for a few seconds to reset the device.
    • 2
      Wait for the home screen to appear, then hold down the "power" button on the front of the Wii until the power light turns red and the Wii shuts down.
    • 3
      Unplug the Wii's power supply from the wall outlet or power strip.
    • 4
      Leave the Wii console unplugged for at least five minutes. Reconnect the power supply and press the power button to turn the Wii back on and complete the hard reset.
Nov 06, 2011 | Nintendo Wii Console
The Wii console light will turn green
Hi sharonkayh,
Try the following:
1) Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2) Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved.
This is done by:
  1. Make sure your Wii console is successfully connected online.
  2. Access the Wii System Settings.
  3. Click on the blue arrow twice to reach the Wii System Settings 3 menu options.
  4. Select "Wii System Update" and press the A Button.
  5. Select "Yes," and read any messaging regarding obtaining the update. If you agree to the messaging, select "I Accept."
  6. The Wii console will now search for the latest Wii System Update.
  7. If an update is available, it will be downloaded and installed automatically.
I hope this can help you - Source: Nintendo Website.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 05, 2011 | Nintendo Wii Console
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
May 10, 2011 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
My wii will not turn on
try syncing the wii and the remotes. there is a small red button on the wii covered by a small door. and as for the wii remote, there is a small red button where the batteries are located. hold them down for at least 10 seconds i would say and then try turning it on. good luck.
Aug 27, 2009 | Nintendo Wii Console
Wii shuts down
HI, the power sector has failed in your unit. this will cause the issues you are experiencing at this time. you will need to contact Nintendo at this time. they will issue you a repair ticket so that this unit can be repair. the power sector will need to be replaced(Power component failure).
Jul 28, 2009 | Nintendo Wii Console
System Lockup
Best bet is to contact Ninendo Tech Support at 1-800-255-3700. Hope you figure it out!
Aug 28, 2008 | Nintendo Wii Console
I have this problem with my wii console, i pluged in a game cube memery card, and caused my wii shutted down my it self, and is not able to turn it on again every time i replug in the ac power, it shows...
get a wii memery card and plug it in and your wii does not run if ather software came in its hardrive so get a good memery card and place it in the last slot and turn it on
Aug 01, 2008 | Nintendo Video Game Consoles & Games
Wii standby light
To be precise, you can turn this option off from the Wii System settings -> Wii Connect 24 -> standby connection -> off
When this setting is swiched to off, your console shuts down entirely and there is a RED light on the power button. There will be no need to turn off the console pressing the power button.
Jun 10, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
55 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
