Monitor problem philips 170c 17" powers up shows pic for short time screen go's blank green light stays on can any 1 help thanks
  • chino_2000 Oct 16, 2008
    the central processor unit doesn't recognize the monitor
  • razvanbta Feb 21, 2009
    hy, the monitor starts it shows the image (Check cable connection ) then it goes down , but the power led remains green . The monitor it is not connected to the pc . It does the same thing when is connected or when it isn`t. What should i do ?
    Problem Solver:
  • 10 Answers
It may be a problem with the playback of your monitor or just the pins at the back of the tube of your monitor. but first check your videocard. check the connections or uninstall the card, clean the contact points of your videocard and install it again.
Posted on Mar 15, 2008
Monitor display shows for about 1 second then goes blank but the green light stays lit. If you turn it off and then on again it does the same thing.
Look for bas DC filter caps with leaking/bulging top/seals.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Aug 11, 2010 | Philips 170S7FS 17" LCD Monitor
My Philips 170C monitor does not work when I turn on. It only says "attention signal off".
it thinks this is no input signal. make sure your computer is on and the cables are secure, switch your screen with a known good one from a freind. this will rule out your computer. if the pc is fgood maybe go into the bad monitor menu settings and make sure the input mode is correct. if this is not the cause you may need to have it repair, your monitor video or display board maybe bad.
Dec 26, 2009 | Philips 170C4FS 17" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
HP L1706- screen is blank when I switch on
First if you have a extra monitor try to plug it in and see if it works. If not then check your video card. or get into the computer and try and remove and reseat the memory. Sometimes by just doing that can solve the problems
Feb 06, 2009 | HP L1706 17" LCD Monitor
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Screen's gone blank and the green power button flashes intermittently
This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 24, 2008 | Philips 170S4FB 17" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
Philips 170C Monitor
i believe your monitor signal cable is bad or twisted.try straightening the data cable that connects to your cpu, if it doesn't work, replace the signal cable.
Feb 26, 2007 | Philips 170C4FS 17" LCD Monitor
Computers & Internet Logo
193 people viewed this question
David Payne
David Payne
